Question about Nordic Track NordicTrack GX 5.0 Pro Recumbent Cycle
Resistance motor not working
Display is working, but resistance does not work when you increase it.
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
576i resistance not increasing precor
If the display stays at 1, then the UP button may be at fault, in which case you would need a new keypad.
Jan 02, 2014 | Precor EFX 546i Elliptical Version 4
Resistance on precor 576i will not increase
This sounds like it's the membrane on the console faceplate. It'll have to be replaced.
Jun 23, 2017 | Exercise & Fitness
How do I adjust the tension. Even at zero resistance it is too difficult
Hi Doug,
You may have a problem with the resistance motor. The covers will have to be taken off to fix.
Usually when you increase or decrease the resistance you will hear the motor working. Do you hear it ?
Nov 03, 2013 | FreeMotion 570 Interactive Elliptical
Resistance
This could be caused by either a bad lower electronic board or the brake/generator. I am attaching a link to the service manual for you for further reference. http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/Service%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
Jun 27, 2013 | Precor EFX 546i Elliptical Version 4
Golds gym 380 elliptical is not increasing resistance
follow this steps, God bless you
    • Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
    • Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
Nov 14, 2012 | Golds Gym StrideTrainer 380 Elliptical
How to increase resistance on Blackburn Tech Fluid Trainer? I know it is supposed to increase with rpm's, but I am not a strong rider and I just rode 90 minutes in my biggest gear with only moderate...
Fluid trainers work by providing resistance that increases as your effort increases, much like riding on the road. There is not a switch or lever to increase the resistance with this specific trainer. So in short you have to put in a bigger effort to get more resistance. Putting in more effort and increasing your Cadence (rpm's) will provide a harder resistance and will decrease your duration attainable. This is OK. One of the benefits of using a trainer is that you can get more accomplished in less time.
Mar 25, 2011 | Cycling
What is the function of the motor relay on my master 110,000btu heater The relay,capacitor,or overload has an ID # Murata 60 PTH491A01 AS3RN160. The Motor does not start strong after multiple starts.
The PTH491 is a ptc thermistor. Its low resistance when off allows a maximum current to flow in the starting winding. As the temperature increases, so does its resistance. The starting winding is essentially isolated from the running winding once the motor has reached operating speed because of this increase in resistance.
Jan 05, 2011 | Master Heaters M125AT
The resistance on my Precor elliptical 5.17 will not increase. All other functions on the machine work. Any ideas?
open shroud and find the circuit board unplug and plug back in all connection this may sometime clean any oxidation off the connector. this is what I've in their 546's should work on the 5.17
Feb 28, 2010 | Precor EFX 546i Elliptical Version 4
My 1993 concorde has a problem with the power windows. After driving for about 10 minutes the controls won't work. The fuse is very hot to the touch. After the car cools down the windows will work again...
I dont know if it is a fuse that is hot, maybe a Circuit breaker that got hot.
Law: With increase resistance Increase Tempurature.
Something is Acting as resistance in your window switch or on the motor or the window itself (ei tint)
One simple things you can do to help this would Be to clean the Glass of your car And the Lttle **** of the door where the window slides up and down.. And remove Excessive Tint.
If the windows still do not react until cool, then it could be your motor with high resistance.
Jul 15, 2009 | 1993 Chrysler Concorde
Nordic Track NordicTrack GX 5.0 Pro Recumbent Cycle Logo
93 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
