Question about Ozeri Scale. Touch Digital Bath Scale in Black ZB13
The ozeri bathroom scale is showing kilograms
I tried a lot and it still won't work
Why will my bathroom scales, Model TH 321 not show weight, but only zeros?-
SOURCE:Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Jan 02, 2018 | Health & Beauty
For a Toshiba bathroom scale, how do I change from kilograms to pounds?
1 kilogram is an equivalent of 2.205 pounds. Do the maths
Oct 17, 2017 | Toshiba Health & Beauty
HOW DO I CHANGE BATTERIES IN OZERI BATHROOM SCALE MODEL ZB13
On the back of the scales under the Ozeri sticker, you will find the battery cover. Remove the cover and replace the two CR2032 batteries (model ZB13).
Sep 04, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
Tn425 sharper image bathroom scale how to change from kg to pounds?
There is a small finger slider switch underneath the scale, setting the scale to either pounds or kilograms.
May 07, 2014 | Terraillon TFX70 Sharper Image Body...
How do I restart my Ozeri ZB13-W after replacing batteries?
Should start right up. Check make sure batteries are good and properly installed. If terminals are dull looking shine them and reinstall batteries for a good connection.
Apr 24, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
Ozeri ZK 14, error code oVE2, what does it mean?
oUt2 means that it needs to be calibrated. I am not familiar with these scales so no sure if they can be re-calibrated.
Jan 25, 2014 | Ozeri Pro II Digital Kitchen Scale in...
Manual for ozeri zb13
search on google for Ozeri zb13 manual.
Dec 07, 2013 | Ozeri Scale. Touch Digital Bath Scale in...
EKS bathroom scales Model:8901BM DC:3403 I need to know how to change weight units from Kg's to Stones and Pounds.
Turn the scales over so that you're looking at the underside. You will see a 2-way switch that says "Kg" on one side and "St" on the other... Choose either kilograms or stones.
May 08, 2011 | Home
Hi. I have a Produex glass bathroom scale. I have no idea what model it is and I can't find the instruction manual. Somehow it got switched from pounds to kilograms and I don't know how to switch it back....
I have a produex glass scale that is silver with a solid black stripe on one side and rows of poka dots on the other side. It has a tiny swicth on the back that changes the scale from pounds to kilograms.
Jul 27, 2010 | Health & Beauty
Ozeri Scale. Touch Digital Bath Scale in Black ZB13 Logo
29 people viewed this question
Top Ozeri Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Ozeri Health and Beauty Expert? Answer questions, earn points and help others
