Question about LG Metro Pcs Optimu Ms690 Touch Screen Android Smart Phone Ob & Accessories
Wifi not working
Wi Fi doesn't work very often.
Carnot connect to wifi
Make sure the router is working as it should.
Mar 19, 2017 | Cell Phones
Tip
How to Fix iPhone 6/6 Plus Show WiFi Problems
"Anyone experiencing really slow WiFi on their new iPhone 6 Plus? Mine is super slow. When I switch off WiFi, LTE works perfectly and very snappy. I didn't have any issues with my 5s and not having issues with my iPad Air. I doubt it's an iOS 8 issue because the 5s and iPad Air are running iOS 8. WiFi also works fine on my 13" MacBook Pro Retina. It's not a router issue. Any ideas??" asked by Mikef91 on the Apple's office discussions.
As one of the leading wholesale cell phone parts supplier online, DBXStore find some solution for you to fix the show wifi problem on your iphone 6/ 6 plus.
Greyed-out, slow or no Wi-Fi signal at all are among the top three biggest Wi-Fi headaches. Even though the iPhone 6 and iPhone 6 Plus came with iOS 8, Wi-Fi problems are still not completely avoidable. Before searching for solutions to Wi-Fi related problems, always update your device to the newest version of iOS. If that doesn't work, then it is time to dig deeper.
1. Reset Network Settings
Settings > General > Reset > Reset Network Settings.
This is a solution suggested by Apple Service. Resetting your network settings including Bluetooth pairing records, Wi-Fi passwords, VPNs, and APN settings; which flushes cache and clears DHCP settings and other networking related information.
2. Disable Wifi Network Services
Settings > Privacy > Location Services > System Services.
This only relates to your location being used for network and not the Wi-Fi itself.
3. Switch DNS To Google
Often times, if your ISPs DNS servers are having problems, you can switch to Google DNS by going to Settings > Wi-Fi then tap the "i" icon next to your router, scroll down to DNS and tap the numbers, then enter "8.8.8.8". Restart your device and check if it works.
4. Change The Routers Broadcasting Band
Change the routers Wi-Fi broadcast from an N network to a G network, or from 2.4GHz to 5GHz - this depends on your individual router hardware.
5. Factory Reset
Settings > General > Reset > Erase all Content and Settings > Erase iPhone.
Last but not least, restore your iPhone and set it up as a new device.
Other tricks like placing the iPhone 6/6 Plus in a refrigerator, freezer it for 15 minutes, or the opposite using a hair dryer to heat up the device might also be of help.
However, if all these software related tricks don't help, it could possibly be a hardware problem with the Wi-Fi antenna. Then the only fix is to replace your antenna with a new Wi-Fi antenna replacement. Here are links to the parts and tutorial guides' for reference.
on Jul 23, 2015 | Apple iPhone 6
How do I get the wi-fi- working on my laptop after installing windows 10?
try typing wifi or wlan in the search box or windows wireless, that may throw up results for you to trawl through
Oct 26, 2015 | HP Pavillion G6 1d72nr I3-2350m 15.6"...
Why won,t ipad connect to wifi , keeps saying not connected but was 2hours prior
are there any other devices connected to the same wi fi are they working ?
TRy powering down wi fi router
Feb 20, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Wi fi not working
Apple products for cell phone and tablet. if yes turn off wi fi on these devices and try reactivating Wi fi. Try changing encryption to WPA rather than WPA2 on wi fi router.had similar problem I solved with apple iphone 5 for a friend I helped.
Apr 19, 2014 | Tablets & eReaders
No wifi possible
do you get an error message? Do you still see wifi networks being detected? more information please.
Jun 11, 2012 | Computers & Internet
Won't connect to Wirelss hot spots outside of home. Wi fi at home works but anywhere else I just get a Error code 003-3201 pops up.
Is the Wifi strong enough to go outside with it? Do you change the WiFi spot outside of your home? For example, if you are at a gas station, do you connect with your home network? This doesn't work.
May 26, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
I need to install wifi software to my nokia 5310,any solution
Ok for starters your Nokia 5310 is not a SMART phone so you will not be able to install WI-FI software! Even if you could your phone would have to have WI-FI components built into the phone for WI-FI to work. If you need WI-FI try looking at some of the Nokia N series phones like N95 etc. Because they use Symbian Software they are capable of running applications that can control WI-FI and GPS etc.
Jun 21, 2009 | Nokia 5130 Cellular Phone
WI-FI
if you have the same problems with usb then your problem lies outside the laptop. if your led does not light it is possible your laptop wasnt wired for wifi or your led is not working. Where you place the wifi card is there 2 wires 1 black and 1 white
Aug 29, 2008 | Toshiba Satellite A10 Notebook
LG Metro Pcs Optimu Ms690 Touch Screen Android Smart Phone Ob & Accessories Logo
12 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
