Question about Insignia Digital-to-Analog Converter for Analog TVs
How do you tape on vcr from a vcr? - Insignia Digital-to-Analog Converter for Analog TVs
  • Insignia Master
  • 5,568 Answers
The 'quick and dirty' way is to connect the VCR playing the tape via the RF OUTPUT coaxial connector to the RF (sometimes ANTENNA) connector on the recording VCR with it set to channel three or four. BOTH units must be set to the SAME channel. The better way is to use the RCA jacks and all but the very oldest should have a yellow jack (Video) output connected to the other unit's (yellow) video input and for sound, the output white jack connected to the white input jack (left channel) and the red output jack would go to the red input jack on the recording unit. This latter method yields a cleaner signal than the first method.
Posted on Jun 14, 2009
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
GE vcr tape stuck
when this happens to me, i disconnect the vcr and remove the screws to the top cover. i remove the cover and carefully remove the tape, being careful not to touch any of the parts of the vcr. but please make sure the vcr is un plugged.
Dec 08, 2008 | GE VG4052 VCR
Vcr says that there is a tape inside of the vcr when there isn't
Most VCR's do have a sensor system inside. It consists of what looks like a bar that is standing up right in the middle of the area the tape sits down into, and sensors on one or both sides of the tape bay that detect this source. The source is usually an infrared diode, and it is most likely this diode that has malfunctioned. I would checjk to see if anything has gotten inside that might be blocking this sensor, if not then the diode probably needs replaced.
Dec 08, 2008 | Sylvania 6240VE VHS/S-VHS playback VCR
VCR playback sound and pciture don't match
That is a tape path issue. The new VCR has the problem, usually the guide post for the tape sticks out when it shouldn't making the sound late for the picture because the gap between the video head and audio head is wrong.
Mar 31, 2017 | Philips Magnavox 20MC4304 20 in....
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
VHS Tape on Sanyo Doesn't play on other VCR's
the heads on the sanyo vcr may slightly be out of alignment from years of use.when playing a recorded tape from this vcr to another, the other vcr's alignment maybe right on track thus causing the poor quality.you can possibly try cleaning the heads with a head cleaner or a high grade blank tape,but i don't think this will solve the problem. but you can try.
good luck
wg
p.s also try higher quality tapes to record on.
Feb 04, 2008 | Sanyo VWM-900 VHS VCR
VHS tape
is it a specific one particular tape? Or is it that all VHS  tapes that you put into the VCR or Rewinder do not rewind? Do clarify
Oct 24, 2007 | Optical Coating Model 108 VHS VCR
Insignia Digital-to-Analog Converter for Analog TVs Logo
55 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
