Question about JVC Televison & Video
Rcr312wv program code
Give me answer
Do you have codes for universal remote rcr312wv
Code link attached.
RCA Remote Code Finder RCR312W
I also included link to instructions, If what you are looking for is not listed, you may need to use the "finder" procedure...
http://voxrightnow.custhelp.com/app/answers/detail/a_id/8098/~/programming-the-rca-rcr312wv-universal-remote-control
Dec 30, 2014 | Televison & Video
I need to know how to program universal remote rcr312wv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
How to program remote RCR312WV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
Sep 26, 2014 | Televison & Video
Where is the set-up button on the Rca RCR312wv remote control
The component key is the setup key. To program the remote, press and hold the component key that you want to program. Then when the On-Off light turns on and stays on, enter the first code for the device you want to the remote to control. Then release the component key and check if the code controls your TV. (Some codes may only control some functions so try all the keys you will want to use before deciding that you have a good code.) If the code doesn't control all of the features, repeat the steps from holding the component key and try the next code.
For Panasonic TVs try the codes 1003, 1054, 1055, 1062, 1109, 1130, 1170, 1248 .
The RCR212W manual is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RCR312W_DOC_OM.pdf .
Please note that the codes in the universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a newer remote.
I hope this helps.
Oct 11, 2011 | RCA RCR312W Remote Control
Panasonic tv codes RCR312wv
To program the remote, press and hold the component key (TV, for example) that you want to program. Then when the On-Off light turns on and stays on, enter the first code for the device you want to the remote to control. Then release the component key and check if the code controls your device. (Some codes may only control some functions so try all the keys you will want to use before deciding that you have a good code.) If the code doesn't work, repeat the steps from holding the component key.
Panasonic TV codes to try 1003, 1054, 1055, 1062, 1109, 1130, 1170, 1248 .
Please note that if your TV is newer than your remote, you may need a new universal remote. The codes in the remote are limited to those for devices released 6 months or more before the remote was programmed.
I hope this helps.
Oct 11, 2011 | RCA RCR311S Remote Control
I need to find some codes for a rca universal remote the model # is rcr312wv and its for a insignia tv.
Hello
Insiginia is not liste with the remote contro you specify here. It is possibe to get the code for your TV by search method.
Throughout the programming
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
Press and release the ON•OFF key
repeatedly until your component
turns off. Wait 4 seconds between
each key press. Each time you press
the ON•OFF key, the illuminated
ON•OFF key blinks, and the next
code is sent. The Brand Code
Search begins with the first code in
the chosen brand list for that
component and cycles through all
the codes for that brand. If your
component turns off, you have
found the correct code. (If it cycles
through and the illuminated
ON•OFF key blinks four times and
turns off, all codes in the chosen
brand lists have been searched. The
Brand Code Search mode is exited.)
Mar 23, 2011 | One For All URC-4021 Remote Control
Remote problems need code for rcr312wv to sanyo
Hi, the code you are looking for is:
Sanyo - 10054
Feb 12, 2011 | RCA Televison & Video
I am trying to reprogram my Duraband tv with my RCA remote(RCR312WV R20052 3934EW
I do not find an RCR312WV remote from RCA. The code finder list is here: http://remotefinder.rca.com/default.aspx?site=rca . The site works with IE 8 but not with my Firefox browser.
Most Durabrand TVs were made by Funai; so try the Funai codes. For the RCR311W, the codes are 1038, 1046, 1047, and 1189.
Please note that the remote will only have codes for TVs released 6 months or more before the remote was programmed. If your TV is newer, you may need a newer remote.
I hope this helps.
Dec 08, 2010 | Televison & Video
I HAVE A RCA REMOTE THE NUMBER IS RCR312WV ORR20052 OR1945EW I WANT TO PROGRAM MY MAGNAVOX TV
Hi, its an older model but this is the code list for Magnavox listed in the rcr312w manual: MAG......................................................................................... 11498 Magnavox............................... 11454, 11866, 11755, 10054, 10051, ......................... 10030, 10096, 10802, 11198, 11254, 11963 I f this does not work you can download the complete list from www.rca.com
Oct 27, 2010 | RCA Televison & Video
How to program an rcr312wv
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Aug 02, 2010 | RCA Universal Remote Control
Televison & Video Logo
11 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
