Question about Vehicle Parts & Accessories
Oil level switch 2007 silverado add engine oil
Indicates add engine oil, level on dip stick indicates full
    New Friend:
  • 35 Answers
The switch is on the right side of the oil pan It screws directly onto the pan
Common problem
Posted on Apr 23, 2014
How to tell the motor oil is filled on the dip stick
The dip stick has markings on it showing the level it should be at.
Jan 04, 2016 | 1997 Cadillac Eldorado
Oil can indicator remains on while driving
If it drives OK and doesn't start knocking. Replace the oil sender unit.
Apr 28, 2015 | Nissan Cars & Trucks
Peugeot 106 warning & oil light comes on when car is started & whilst driving turning corners?
Check the oil level on the dip stick in your engine. If the dip stick indicates you are low on oil add the proper oil for your make and model.
Jan 21, 2013 | Cars & Trucks
Oil dipstick tube broke
look on dip stick you should see cross hatched area with add oil or oil full mark.if you wipe oil dip stick with a clean paper towel and dip stick look dry no sign of oil add little oil at a time see if oil level reach add oil mark or the full mark.if oil is low. low oil light will turn on if bulb is blowed but if dip stick look dry oil level could be low,add little bit at a time dont over fill.
Feb 16, 2012 | Cars & Trucks
Have you ever heard of the engine oil reservoir being full and the dipstick reading empty? I just bought an old 1985 toyota pickup truck and it was fine until I had my oil changed. After driving for a...
When your car is low on oil, there is a sensor (sometimes called a switch, as well) that will light up an indicator inside the car to inform you of the low oil level. In some cases, checking the dipstick will show that there is actually oil present, which can be confusing and frustrating because it contradicts the sensor. If this happens to be the case, more than likely the oil pressure switch/sensor is malfunctioning and will need replacing.
Keep us updated.
Nov 15, 2010 | Toyota Pickup Cars & Trucks
How do I add oil? Where is the oil fill located?
LOOK UNDER THE HOOD LOOK ON FRONT VALVE COVER THATS WHERE OIL FILL CAP LOCATED.YOU HAVE A OIL LEVEL DIP STICK BELOW THE FRONT VALVE COVER.LOOK ON THE OIL LEVEL DIP STICK WHEN ADDING OIL DONT OVER FILL THE FULL MARK LINE ON OIL DIP STICK THAT WHERE YOUR OIL LEVEL SHOULD BE DONT GO PASS THE FULL MARK.
Aug 12, 2010 | 2005 Chrysler Town & Country
Can ODB2 READERS READ THE TRANSMISSION TEMP ON THE
code readers cant.the scan tools can but are real expensive.if you havent drained the trans oil yet just drive it around a while and check it.if you have drained the oil then try to measure what you took out and put that much in.if you cant measure old oil then add fluid while engine running in nuetral{double check the nuetral position writen on dip stick} add fluid untill oil is below the add level let it run for a while say 30 minutes and recheck add th full then go drive it around.recheck again if low add if high drain out or siphion some out throuh small hose through the dip stick tube
Mar 19, 2010 | 2007 Jeep Grand Cherokee Overland
MY SATURN 1 SHOWS NO OIL WHEN IT IS COLD BUT WHEN CAR IS TURNED ON IT SHOWS FULL WHY IS THIS
To check engine oil level engine needs to be off, if check while engine running, oil will splash inside oil pan and all over your dip stick giving you bad reading, Check oil level with engine off and add to full mark on oil dip stick. Running engine with low oil will cause major damage to your engine. To check transmission level engine needs to be running at normal engine temp.
Nov 16, 2009 | 2000 Saturn SL
When do I add Oil?
Really you should not have to add oil. But to find out have jeep on level surface and use the dip stick to check. Check with car off, pull dip stick out and wipe off and reinsert, Pull back out and read the stick only add if it is low. Do not over fill.
Sep 23, 2009 | Jeep Cherokee Cars & Trucks
Vehicle Parts & Accessories Logo
21 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
