Question about LG LDS4821BB 24 in Builtin Dishwasher
Lg dishwasher stopped running
Lg direct drive
2 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
Posted on May 02, 2009
My LG direct inverter has a bad smell &; now has left the washing with gunk on the clothes
sounds like the direct drive invertor type motor is going bad you may want to contact LG directly to have this part replaced
Nov 02, 2016 | LG Washing Machines
The drum will not turn on a direct drive lg washer
i would guess bad bearing or broken spider. there are no gears or gearbox on a direct drive LG.
Sep 20, 2016 | LG Washing Machines
Is LG WD10480NP a Direct Drive Washer?
No this is not a direct drive machine such as the whirlpool version
Nov 02, 2015 | LG Washing Machines
How do you operate a lg inverter direct drive washer
it a procedure,read it manual........................or power on nd press the play botton ,,,,everything will operate itself automatically
Sep 04, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
Lg tv vertical line
mostly panel issue but might be also the X-drives boards the x-drives are located in the bottom of the panel and they are horizontal oriented boards connected directly to the panel
May 31, 2014 | LG Televison & Video
Lg Washing Machine Manualmy washing machines just started coming up with 1E in the display part what does that mean.. i have a lg direct drive 7.5 kg front loader, WD12020D
there is a problem in water inlet valve.....first turn off the water tap.then remove water inlet hose from washer end.after that see the inside of the valve.there is a small water filter in the valve.....take it out it using plier ...then clean it wel....now replace it correctly....now your problem will ok
Jun 02, 2013 | LG Washing Machines
LG Direct drive having problems drying clothes
check on the water outlet pump beneath ,,,,,,if there is a sound while drying,,,maybe needs to clean the filter cup,
Apr 13, 2013 | LG WD-1070QDP 7 Kg Direct Drive Washer
What causes an lg direct drive not to spin
your tub needs to be totally empty of water first,if it is then open the top cover and run the diagnostics on the unit,if this fails then the control board is defective
May 29, 2010 | LG WM-2277HW Front Load Washer
Where can you find a drive belt for a LG GSA H62N Super-Multi - Disk drive?
Get on lg website and look for distributers or authorized dealers or you may be able to order it direct from LG , you can also go to appliance parts .com and they will help you.
BGM
Jan 10, 2010 | LG GSA H62N Super-Multi - Disk drive - DVD...
LG LDS4821BB 24 in Builtin Dishwasher Logo
16 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
