Question about Hugo Boss 1502211 Watch
Chormeter watch I can set up my watch the small hands circles
Wenger model 097.0699 has a 3rd hand that relates to a series of numbers 1-24 on a inner circle what is this for?
dual time. You can set the inner hand with 24 hr markings for other time zone. So regular hands for your local time and inner hand for other country or time zone.
May 13, 2014 | Swiss Army Wenger Sportedge Bracelet Watch
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
Please clarify use of the 3 smaller dials and how the hands to each are set and reset
The small bottom dial is seconds counter and there is no option to set or reset it as it is part of the main gear train - it just counts the seconds. Top right dial is 1/10 seconds counter and runs only when the chronograph function is engaged. One full circle indicates 1 second. Top left dial is 30 minutes counter and runs only when the chronograph function is engaged. One full circle indicates 30 minutes, two circles = 1 hour. The big centre seconds hand is actually Chronograph hand and runs only when the chrono function is engaged. So, the chronograph hand and two top dials works all together when chrono function is engaged. To start chrono: push upper button once. To stop chrono: push upper button again (once). To return all hands to zero: push lower button once. There is another option: if you already stopped chrono by pushing upper button, but want to continue counting without returning hands to zero, push the upper button once more and the counting will start from the point where it stopped. You can repeat this as many as you wish - it will count on and on, till you will stop it and reset to zero. Fine tuning of chrono hands can be made by pulling the crown half way out and while leaving in this position pushing and holding one of the push buttons (which one - depends on movement caliber). Watch has an tachymeter function as well (big inner ring). Learn how to use it by browsing through my Tips and Tricks- it is explained there. Rate me, please.
Feb 28, 2011 | Calvin Klein K7547107 Celerity Watch for...
Describe your Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Problem: How to correct 0 position of 24 four hour hand. I think its done in conjunction with hour hand but how?
Here is how to correct the 0 Position for your watch.
While your the crown of your watch is down in the starting position , turn the crown until the mode hand (this is the circle at the bottom of the face) reaches CHR
At this time now pull out the crown until it clicks two times, two the second setting of the crown.
This will bring the watch to the 0 position correction function.
you can turn the crown clock wise to correct the hour hand.
press the a button to switch hand to second, or press again to switch to minute. Then use crown again to correct 0 position.
The hour and the 24 hour hand is in conjunction with each other.
then push down the crown all the way in and you should be all set.
Oct 18, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Emporio armani 4211
mcdevito75 here, There are 2 ways to wind your Armani Emporio watch, I'm figureing it"s an automatic watch, on some automatics you can start an initial ticking by winding the stem in any direction, if when you wind the stem you feel any resistance then this is the type of automatic watch you Start with about 20--30 winds of the watch. If on the other hand when winding the stem feels very loose and free, no resistance at all, then this is the type of automatic that relize on pure wrist and arm motion to start ticking, simply hold the watch in your hand and make small circle motions, or rocking motion, you should detect something moveing inside the watch, this is the winding counter balncer it's normal, rock or circle the watch for approx. 30 seconds to get it started. In both cases, after the watch starts, the motion of your wrist / arm keeps it wound as you wear it.
Jul 10, 2010 | Giorgio Armani Emporio Armani watches...
Not sure what parts should be moving on new Fossil Me1020 watch.
I have a Fossil Twist ME1011, basically the same idea behind the one you have. What happens is there is a weighted third-circle that is in the back of the watch behind the battery (you can't see it) that spins a spring (the spring is the bottom seethrough part that ISN"T moving!) the spring then moved the UPPER seethrough part, which in turn spins the second hand!
IF the second hand stops working, carefully take the back off the watch and you'll see the weighted third-circle that I was talking about. It should spin, and in the middle there is a tiny flat head screw. The screw can get loose, so gently tighten it and the second hand should work again!
May 30, 2009 | Fossil ME1020 watch
Date change on my Tag Aquaracer Calibre S
Do as follows:1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
Now your watch will be changing dates at midnight continuosly.
Rate me, please.
Apr 06, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Date function notworking properly
Do as follows:
Rate me, please.
Apr 04, 2009 | Tissot Le Locle T41.1.423.33 Watch for Men
Set?
Press Both side buttons at the same time. This should reset the hours and minute mini-circles. Then use the top button to "start" the second hand moving again. press it again to stop the second hand. I'm unaware as to how to restart the bottom seconds circle.
Dec 03, 2007 | Fossil FS2920 Wrist Watch
Problem with second hand
I need to know what type of oakley is this .. i mean what model .. because they have different specifications..
Dec 26, 2006 | Oakley GMT OAK0531 Wrist Watch
Hugo Boss 1502211 Watch Logo
14 people viewed this question
Top Hugo Boss Watches Experts
Tom Chichester
 steve
steve
TIME TRACK SERVICES
TIME TRACK SERVICES
Are you a Hugo Boss Watch Expert? Answer questions, earn points and help others
