Question about Sharp AR-5316 Advanced Digital Imager Copier
Looking for installer of scanner and printer - Sharp AR-5316 Advanced Digital Imager Copier
Installing the scanner/printer use software driver CD or download from the website for the correct operating system software of your computer.
Newton
Posted on Mar 24, 2014
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
Hi! I have a Di 1610 copier/scanner & printer. I lost the installer we cant use the scanner..How can I install the printer with the scanner? thanks
Janiz your problem should be an easy fix. Head out to your favorite search engine and type the name for your printers manufacturer (konica) and go to their website. From there navigate to a search or product listing and find your printer/scanners product id (di16110p). Next, find the downloads related to that model and look for the drivers for your operation system. Make sure you download the correct driver or this will not work. Good luck, and update/reply to your question if anything goes wrong.
May 14, 2011 | Konica Minolta DiALTA Di1610p Printer
How do I install my scanner so that Im able to scan pics?
GO TO HP.COM AND DO A SEARCH FOR YOUR AIO INKJET PRINTER AND LOOK FOR THE MANUAL FOR YOUR PRINTER. DIRECTIONS SHOULD BE IN THE MANUAL ON HOW TO INSTALL YOUR SCANNER.
Nov 06, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My scanner is not able to be found. my psc all-in-one prints just fine, but the scanner doesn't work. is there a scanner drive i should reinstall?
go to control panel and remove driver installed. restart pc and reinstall driver in full install option (don't plug yet the usb cable) when installation on going pup up appeared to insert printer ( that's the time to insert usb cable) and click continue installing tell it finish. restart again and look for scanning tool from destination folder.
Feb 09, 2010 | HP PSC 1410v All-in-One Printer
Need software for the scanner
Canon have all their drivers available on their website. However, if he installed the printer driver then I would expect that he also installed the scanner driver (on every Canon Multi I have installed they are both done together automatically by the installer software.
To find out if the driver is there, open your applications folder and look for 'Image Capture'.
Open it and see if identifies your scanner (make sure it's switched on of course). See if you can scan from there.
Post back and let us know.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I hit scan on my machine and there is nothinbg responding on the computer screen. I am able to copy, print and fax. Help.
Your scanner is not properly installed. It is a separate part of the program. If you have (start - programs) the scanner as a program, bundled with your other printer proograms on screen, double (left) click on the scanner program, it should lead you to the install wizard. simply install the program. If not, try reinstalling your printer.software (use control panel - add/remove - uninstall all printer programs FIRST). Look at your software and make sure that the scanner software IS included.
Sep 01, 2009 | Brother MFC 210C All-In-One InkJet Printer
To get installation drivers of lexmark scanner and printer ( x 1270)
hello sir.
plz donate if you can and rate madridtelecom@gmail.com
click here to choose ur OS
Feb 08, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X5150
JT, install the scanner unit via windows as a new scanner (start, printers and scanners, new device) and browse to the unzipped files when windows asks for installation files, this should make the scanner part work.
Jan 27, 2009 | Lexmark X5150 All-In-One InkJet Printer
Dell AIO924 printer
you may need to install the whole cd package w/c includes the scanning application program, or you can try using a sifferent software like the one in windows, under accessories look for scanner, if your system cannot find the scanner, then the driver for the scanner wasnt fully or not yet installed,
pls look for the scanner software, what you have installed is only for the printer alone.
cheers
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
No drivers found
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
If it is not installed properly and working there should be a yellow triangle with an exclamation mark inside it next to the scanner name.
Whatever it says, right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready to use, re-install the scanner driver do not plug in the scanner yet!.
Once it has finished installing, re-connect the scanner USB lead.
Windows should install the drivers and tell you the scanner is ready to use.
Apr 24, 2008 | Canon CanoScan 4400f MultiFunction Color...
Sharp AR-5316 Advanced Digital Imager Copier Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
