Question about PixiModo Reflection 15M 15-Inch Digital Picture
Pictures don't run in order
Pictures from camera have not gone in order when on picture frame since we bought it.
Ativa picture frames troubleshooting
i lost my charger to my ativa digital frame
Aug 30, 2013 | Cameras
Dynex picture frame
A user manual is here
http://www.manualowl.com/m/Dynex/DX-DPF7/Manual/198244
It says there to load photos in from a memory card, such as a SD card, or from a USB stick.
Jun 02, 2013 | Photography
What is frame number reset on my sanyo vpc-s1085. I read the manual and the answer is vague. what is it for do I cancel or execute? I'm also trying to find out how to let the numbers for the...
If you decide to reset the numbers, your camera will start numbering the new pictures from 000 all over again. This can cause problems when you try to download because your computer will think you've already downloaded pics with those numbers. Don't reset....your camera will continue to number the pics consecutively even after you download and empty the card.
Aug 17, 2011 | Sanyo VPC-S1080 Digital Camera
Lost handbook, don't know how to transfer pictures from card to picture frame.
My guess would be that your picture frame comes with some sort of cable to hook to the computer or a memory stick that will connect also.
You just need to plug both in and drag the files from the memory card folder to the picture frame folder.
I'm happy to assist further should you need help.
May 07, 2011 | Cameras
Vivtar Freelance Camera...All pictures gone!
Most likely, yes. Try to use a USB card reader. Take the card off the camera, put it in the reader and connect it to the computer. If there is no sign of files, download PC Inspector File Recovery, install it and run it. You can get it from here: http://download.cnet.com/PC-Inspector-File-Recovery/3000-2248_4-10118663.html
Good luck in saving your pics.
Apr 12, 2010 | Vivitar ViviCam V15 Digital Camera
Downloaded pictures from camera go all over
You check the frame settings and see if the shuffle option is activated. You need to turn off the shuffle option for the oldest-newest order to take effect. Also, you may want to reset the frame. Press and hold the volume (+) and the power button at the same time to reset the frame to factory default.
Mar 31, 2009 | Kodak EasyShare EX1011 Digital Picture...
Can't transfer photos from computer to digital frame
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw)
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
How do I load pictures from my computer to the memory card in my camera?
You have to first download the images to your computer and Save them in a folder. Then connect the USB cable from the digital photo frame to the computer and transfer the photos you want onto the frame. Some time you have to change the photos name to alphabetic order so you photoframe will display the pictures in the correct order.
Feb 20, 2008 | HP Photosmart 635 Digital Camera
PixiModo Reflection 15M 15-Inch Digital Picture Logo
27 people viewed this question
Top PixiModo Photography Experts
Tony
Are you a PixiModo Photography Expert? Answer questions, earn points and help others
