Question about KitchenAid Food Mixers
Kv25gox broken lift
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
My handle on KitchenAid KT26S1X Epicurean Stand Mixer is jammed and won't lift or lower bowl. Can you advise?
I'm not familiar with that particular model but the common cause of that fault on the ones I do work on is a broken or cracked lift lever inside the stand. You need to remove the stand from the motor housing. 4 screws going up through the stand into the underside of the motor casing at the back. That will expose the lift lever mechanism for you to identify the problem.
Jul 14, 2014 | KitchenAid KT2651X Epicurean Stand Mixer
Will not start
I am having the same problem. I just noticed the piece of a part in the bottom of the machine. The hole where the bowl fits into is supposed to have a stop feature. Mine broke off and is in the hole beneath the lift arm. If you raise the bowl lift without a bowl in it, you will see a hole with screen mesh. That is where I found the broken parts. Now I have to find out where to get it fixed.
Jan 11, 2014 | Avantco Equipment Avantco MX10 Gear Driven...
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Hobart AE200 gave a little sproing and stopped turning on all gears (electric motor turning fine apparently). I figure ?maybe it's the tufnell cog that's broken, but I can't get the inner plate off to...
The problem you are describing if I follow right I take the grease hole plugs out take the two spanner nuts off the man shaft and the driven shaft stick gear puller jaws into grease hole and put the gear puller onthe center saft and gently raise the top case.
Apr 18, 2011 | Hobart A200 Stand Mixer
Sunbeam Mixmaster... where's the model number?
Lift up the head, should be right by where you insert the blades
Jan 24, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Bowl Lift Mixer does not lift!
well first you shoul read the menual to repair and then call the company and u can replace it.
Jul 23, 2009 | KitchenAid KP26M1X Stand Mixer
Printed circuit problem kitchenaid mixer stand
That part is named "speed control switch" #PS889134 about $65
A number of web sites stock this part.
Oct 18, 2007 | Food Mixers
Food Mixers Logo
35 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
