Question about LG 32LB9D TV
No sound out put from the tv - LG 32LB9D TV
Why can't I get picture or sound when my Sound Bar, TV and Blu-ray player are connected?
You have to run an audio cable from the TV to the sounder and put the sounder on the TV input for sound to work. The first choice audio cable for best sound would be optical cable if your tv has optical output on it. If it does then you would put the sounder on the din input for sound when watching antenna or any hdmi source connected directly to tv. If your TV only as analog rca out or mini audio out then put sounder on aux input. I think your sounder came with mini to mini stereo cable. If your TV doesn't have mini audio out the get a optical cable or you can find a mini to rca red/white will work. Optical is your BEST connection and soundbar would stay on din all the time for best sound.
Feb 10, 2015 | Vizio S5430W-C2 54-Inch 3.0 Soundbar Black
No sound
your audio ic is probly done..take the audio output from the back of the tv..if you have one..and put it into an amplifier to hear sound..
Mar 08, 2014 | Televison & Video
The sound is not working on my hisense tv
did you check in the screen sound set up menu if the speaker is set to off. if the settings is good, tried to hooked up a powered pc speaker at the audio out jack of the tv. if you can get sound there then the problem it could be the amplifier circuit. if you can not get sound the the cause will be the sound processor at the main board.
Jul 23, 2012 | LG 19LD350 19Inch 720p 60Hz LCD HDTV 19 in...
Well my tvs sound went out about a day ago and it hasnt worked sence
Sound system has a built in pre amplifier in it, the out put of that is tapped via a jack to the out put of a/v.
procedure
turn on tv and get head phones if you have and connect direct on the audio out put of the tv if sound comes out then problem not with tv, but if it does not come out then problem with tv preamplifier.
if you can test take that tv to a repair shop
okay
Dec 27, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
None of my HDMI jacks put out any sound but puts out pic, just stopped working for no reason
check sound setting on tv or audio out on the unit your trying to get sound out of
Dec 26, 2009 | Westinghouse TX-47F430S 47 in. LCD TV
No surround sound on ps3
Set the sound out put on ps3 to the optical out put then set sound on ps3 to give you dolby digital,dts,aac etc.
PS, do not set the hrtz range above 100 as this can damage your speakers.
hope this helps.
CABLE GUY.
Jan 05, 2009 | Onkyo HT-SR800 System
No sound
A DVI cable does not have an audio connection, along with the DVI you still have to run an audio line from the device (DVD player, cable box, satellite receiver) to the TV. HDMI contains both audio and video.
Sep 30, 2008 | Hitachi 57F500 57" Rear Projection...
Hooking it up
To get the dvd working hook up to amp with a optical or coax lead to your amp digital in,set out put on dvd to give 5.1 sound,next put a phono cable from cable box to tv input on amp or sat input,now put phono cables from tv audio out to tv or other free input on amp.Set sound to prologic2 and you should have surround sound for all.
hope this helps.
CABLE GUY.
Jun 05, 2008 | JVC RX-6030V Receiver
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
No Sound when I play DVD's
The optical connection on the TV is most likely an input, not an output. You need to connect the Xbox to the receiver, then the TV. If the receiver does not have a HDMI input, use another audio or digital out from the Xbox to the receiver.
Sep 19, 2007 | Yamaha HTR-5940 Receiver
LG 32LB9D TV Logo
24 people viewed this question
Computer Repairing
Computer Repairing
