Question about Whirlpool Kitchen Ranges
Yester day we had a spill of some greasethat lodged between the oven glass door.This is a double oven,that has the inside section wrapped under.I removed some screws to see if the sections would part,to be able to clean,with no luck. Can you give me advice on how to do this.
  • emyaroch Jun 16, 2009
    my problem is that this range is built in to the cabinet and there isn,t any id. on it other thanthe logo on the door.So ido not know its model no. is. the house was built 3 yrs. ago can that be any help?
    cleaning the grease is not the problem. getting the cover to come apart is.
    Genius:
  • 1,341 Answers
I would suggest to get some stong kitchen grease cleaner and clean it.If you have no expertise of what you are doing then it may end being costly to you.My advise have it clean is better that removing it..
Posted on Jun 16, 2009
  • 377 Answers
Try to use a gasoline pour some gasoline in a piece of cloth and then wipe it where the grease spill i can assure you that the grease will be remove.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
    Genius:
  • 1,689 Answers
Hi Emyaroch,
Thanks for using fixya.
For us to be able to provide a more accurate answer to your question, may we know what is the modem number of your range?
For starters, here is some blown figure of most WP kitchen ranges.
http://images.owneriq.net/download/images/9/96dc0823-ba3e-d254-e917-ad6b25a9d217-000001.png
http://content.searspartsdirect.com/lis_png/PLDM/W0106092-00008.png
hope this helps.
regards,
voodoo
Posted on Jun 14, 2009
We have a Kenmore double oven. Awhile back something spilled as it was being removed from the top oven, and spilled onto the door of the lower oven. Now the glass inside the lower oven door is streaked and...
Please follow the below steps
1)Open the door.
2)Check the hinges and let the door be opened in half way.
3)Use Philips screw head at hinges screws.
4)remove the door and take the inner part alone.
5)Just follow the picture for more help.
Clean it and place it again.
It is very simple you can easily clean it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 07, 2011 | Ovens
Food has spilled into the holes in the door that are hard to reach. how can I clean it?
Go to the following site for full details on how to remove and clean oven door glass.
WWW.YOUTUBE.CO.UK
In the search box, enter---Cleaning oven door glass.
You will find at least one video showing the steps to do this.
Dec 13, 2010 | AEG D2100-4 Electric Double Oven
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Frigidaire double oven - stove top oven had a spill. The spill went through the bottom oven's door vents and is now in between the glass and I cannot get to it to clean. How can I get this glass clean?
I had a similar problem with a spill running into the vent and between the glass. I had to take the door apart clean it and then put it back together. It sounds hard, but it was just a few screws and a little time.
Jun 27, 2009 | Kitchen Ranges
Cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Feb 04, 2009 | Ovens
The Glass from the front of the oven door is off.
the glass on this door, is held up only by the lower trim, and sits behind the handle escution(very small contact point) as far as the trim for sides, the slip under top esctution,and behind the door glass(sorta keep the glass from contacting the metal frame of door.} much easier to do with door off of unit, refer to manual as how to remove the door if needed
Dec 24, 2008 | Whirlpool GR478LXPS Electric Kitchen Range
Stain inside double glass microwave door
most microwaves have screws on the top and bottom outer lip edges. or under the rubber grommet if it has this .
but this unit should have a 10 year warranty and they may cover this issue call them
http://products.construction.com/portal/server.pt/gateway/PTARGS_0_2_493_204_249_43/http%3B/205.142.52.224/swts_content_files/15315/211253.pdf
Feb 29, 2008 | KitchenAid KEHC379 Electric Double Oven
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
