Question about Microsoft Xbox 360 Console
Xbox 360 hard drive problems
When i turn my xbox 360 on with the hard drive in it, it gets stuck at the boot logo. But when i take the hard drive off and turn it on it boots normally. Will transferring my files to a different hard drive fix this problem?
    Problem Solver:
  • 6 Answers
Try going to wherever you got your system from
Posted on Jun 15, 2009
How to completely reset an xbox 360
  • First of all you must remove all disc from your console.
  • Tested with a single gamepad.
  • Turn off your device.
  • The turn it on using your gampad.Press and hold the Guide button until it turns on.
  • While the device is booting, press and hold the Y button + right trigger. The Xbox 360 logo will appears (keep the button pressed)
  • The device will restart and you'll get the Xbox 360 logo again.
  • The display settings are now reset to the defaults.
Mar 16, 2014 | Microsoft Xbox 360 Console
Where is the reset button on my xbox360
I hope this helps:
  • Remove all discs from your console.
  • Turn off your Xbox.
  • Then turn it on using your controller. Press and hold the Guide button until it turns on.
  • While the device is booting, press and hold the Y button + right trigger. The Xbox 360 logo will appears (keep the button pressed).
Mar 13, 2014 | Microsoft Xbox 360 with Kinect
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Forgot my password
Reset your xbox 360 console
  • Oct 08, 2010 | Microsoft Xbox 360 Console
    New Xbox 360 Arcade, Memory Problem
    Could it be due to the lack of hard drive?
    May 14, 2010 | Microsoft Xbox 360 Console
    Xbox one blinking red light.. 1 not 3,, first time i seen this, fixed many ps3 ylod,, is it the same fix? looking for help here or a good link on repair info
    When you get one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
    Feb 06, 2010 | Video Game Consoles & Games
    MY XBOX 360 HAS 1 RED LIGHT FLASHING, WHEN STOOD ON ITS SIDE THE LIGHT IS BOTTOM RIGHT
    one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables. first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more. If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you. The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
    Jun 06, 2009 | Microsoft Xbox 360 Console
    Xbox 360 elite 1 red light
    The number for Microsoft is usually listed on the back of any game manual.
    I hope I was able to fixya problem, and Happy Gaming!
    Oct 18, 2008 | Microsoft Xbox 360 Elite Console
    Freezing during oblivian
    Oblivion uses the Xbox 360 hard drive to cache game data and in some cases the info stored on the hard drive can get fragmented, slowing down the game's performance. Bethesda has already found out a way to fix the issue. Here is the official word: Oblivion uses the Xbox 360 hard drive extensively to cache (copy and reuse) game data. This is done to optimize all loading the game does. It has been found in rare cases on some Xbox 360s that the cached data can get overly fragmented. This exhibits itself by the game taking a long time to load anything from menus, dialogue, sounds, objects, levels, and more. To solve this problem, reset your Xbox, and hold down the A button as the game is booting up. If any button is held while Oblivion is loading, it will clear its hard drive cache, and create a new one. Once you see the ?Bethesda Softworks? logo video, the game is already loaded, and the cache should have been cleared. Note, this does not effect your game in any way other than loading. You will not lose any saved data.
    Jul 16, 2007 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    69 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Stu Morris K
    shaun taylor
    mitch_3020
    mitch_3020
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
