Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Oil holder
Need plastic holder
    Top Expert:
  • McCulloch Master
  • 2,931 Answers
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Posted on Feb 19, 2018
How do I reattach the motor wire to the brush holder insert? Do I lube the new motor?
On one brush holder you push the clip on the end of the field wire between the bottom side of the square brush holder and the black plastic insert the holder is mounted into. On the other brush holder it pushes between the top side of the brass holder and the black insert. The bearing is pre lubricated but oil the armature shaft before sliding the rear bearing housing on.
May 10, 2016 | KitchenAid KSM150PS Artisan Series Stand...
Renault master side door shows opened
This is likely caused by a defective door ajar switch inside the door on the door latch. I do not have any specific info because this make is not sold here in the USA and that is where Fixya is located.
Jul 13, 2012 | Cars & Trucks
During the printing of a form, a noise occurs as if something is catching & it throws all the printing off to either the left or right, right most of the time. any help?
2 things. First oil the inner bar. the one without the red plastic holder. never oil the bar with the red plastic holder. Second thing coud be the bushings inside the carriage assembly. The are brass and have to be pressed gently and very evenly into the assembly.
May 02, 2011 | AMT Datasouth ACCEL-6350 Matrix Printer
My peugeot 307 gear linkage counter balance
i can't change into 2nd,4th and reverse gears. i think its a gear lever cable not sure doe any ideas?
Dec 27, 2009 | 2005 Peugeot 405
I need the right, black #56, plastic holder,,,mine broke
25 posts - 15 authors - Last post: 12 Jul 2008I also noticed that on the new cup holder, this plastic roller has ... search first... mine just broke today. wtf. it's stuck in the down, ... i only need one cup holder.. i suppose i'll replace it later if i ... of the old cup holder still in the cup holder well, a black plastic roller bearing. ...
www.mbworld.org
Dec 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
Need to change low beam headlamp bulb
The bulb comes out the back, turn th bulb holder a quarter turn CCW abd pull it right out
The low beam is usualy the same bulb as the high beam, about 6 bucks or so
CAUTION Never touch the new bulb with your fingers, it leaves tiny straks of natural oil that will crack a new bulb
Put your hand in a clean plastic sandwich baggie THEN grab the new bulb ahd it just plugh straight in the holder, replace, turn a quarter turn CW and you're dome
Sometimes they're a ***** to gt your habd behind the bulb, but other than that it's easy
Sep 13, 2009 | 2005 Saturn VUE
CAN NOT REMOVE WATER FILTER FROM PLASTIC HOLDER
it will also state to turn of the water supply and release any pressure
Jul 02, 2017 | Maytag MSD2651 HE Side by Side...
Printer cartridge holder is stuck
the metal bar that the cartridge holder travels on may need lubing
get 3 in 1 oil and put one or two drops of oil on the bar and then manually move the holder back and forth a few times to spread the oil
Oct 02, 2008 | Office Equipment & Supplies
Circuit board removal
The whole plastic holder will need to be slide out by removing two screws holding it from underneath. Once you have the whole plastic holder out, remove the "F" connector nut and the power cord from it along with some small plastic like pins that hold the audio/video RCA plugs. Look for a couple of screws holding the board to the holder and then hold the board and slide the holder out.
Good Luck.
Sep 08, 2008 | RCA F35317 35" TV
Bernina Deco 600
Try a dry or powder lubricant in bobin case ,not to mutch ! You must try and remove plastic on right side ,to get to working parts ,do not spray on sensors!
Apr 11, 2008 | Bernina Bernette Deco 600
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
18 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
