Question about ION Keratin Smoothing Flat Iron
Error message appears when power is initiated
Error messages causes it to heat to maximum
Prob light stays on, prob is not connected. Will not allow me to heat the oven to a proper temperature or to turn off. Tried unplugging. Frigidaire fggf3054
Press the probe button and hold for 6 seconds.
Press self clean and toggle until "continue" message appears.
Press start to accept.
good luck!
Nov 27, 2014 | Frigidaire Gallery FGGF3054M 30"...
I have a Kenmore iron that is giving me problems occasionally. Sometimes when i turn it on I get an error code that says "NTCERR". I am thinking that it may be due to the temperature where the...
The message refers to a component that is reading out of the normal temperature range so your theory regarding storage could be correct.
Jul 03, 2017 | Kenmore Irons
I have a Black and Decker D1650. It fell off the ironing board onto the carpet. Now I get error message OR and it will not heat up.
hello,
what his sign indicate is that there is disconnection of power connection over to the element i.e the heater (heat provider).
what you need to do to fix up this problem is to open (unscrew) it then trace the wire down to the element inside the system it self the element is silver in colour fix up the wire back, to the back of the element then with this the problem of the error message is solve. disconnect all source of power supply to the connected to it .
thank you.
Jun 13, 2010 | Black & Decker Steam Xpress AS250 Iron...
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Black & Decker D 1500 doesn't heat up - error message
For safety purposes, just about any electrical device that heats will have a thermal fuse built into them to prevent fires and these (ALL Chinese) are very poorly made and unreliable in operation. The design temperature is only rarely the same as the actual temperature at which the devices go open and interrupt current. Sometimes, the design temperature is printed on these fuses and they are available as replacement parts but are almost always welded in place and are not practically replaceable. If someone bothers to open the iron, look for a metal tube ~ 3/4" long and 1/4" in diameter with one end wire obviously connected to the case of the fuse and the other centered in a glass seal.
I once had three identical coffee makers fail within a few days of being new and finally took a refund instead of trying a fourth one.
Oct 03, 2009 | Black & Decker Irons
My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Oct 02, 2009 | Irons
Beeping and error message
Your Iron has a faulty circuit board and need to be replaced
Jul 23, 2009 | Black & Decker D2030 Iron
Black & Decker model D1600 iron error message
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit isn't heating anymore, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Apr 27, 2009 | Black & Decker ICR200 Iron with Auto...
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Steam Iron
Try setting the thermostat to a little less than maximum
Sep 14, 2007 | Irons
ION Keratin Smoothing Flat Iron Logo
46 people viewed this question
Top ION Irons Experts
Are you an ION Iron Expert? Answer questions, earn points and help others
