Question about Cisco 7942 Phone - CP-7942G
Will a Blue Tiger dual ear bluetooth headset work with Cisco 7942 desk phone?
Im looking for a cheap dual ear headset that will work with 7942 cisco desk phone
5 Suggested Answers
RPaterson
  • 48 Answers
SOURCE: CISCO 7941 IP PHONE disconnect you out after certain time
Unfortunately this is a very common problem with Cisco's IP Phones. It can be caused by either a faulty hookswitch or a damaged jack. Both of these problems can be remedied by contacting IdacomUSA.
Posted on May 13, 2009
  • 44 Answers
SOURCE: Where can I access user manuals for Cisco phones
I have found this on the cisco site.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8535/product_data_sheet0900aecd8069bb68.html
Posted on Jan 25, 2010
  • 97 Answers
SOURCE: KONCEPT CISCO
If that is going across a routed network, check all your routing configuration. A lot of 'one-way' calls are caused by incorrect routing.
Make sure that the subnets for each of the phones can get to each other, and if possible try putting them on the same subnet for a trial to make sure that works.
Hope that helps!
Posted on Oct 17, 2010
  • 23 Answers
SOURCE: I cannot register phone in remote location
Duplicate question. See other post for clarification.
Posted on Oct 20, 2012
Cisco 7942 factory reset
When performing the factory reset procedure we are about to describe, it is important to keep in mind that the IP phone will lose all configuration files and phone applications. This means that it is necessary to have CallManager or CallManager Express setup so that the IP phone will be able to receive the new information (phone application and configuration) after the reset procedure is complete, otherwise it is most likely that the IP phone will not be usable until this information is loaded on to it.
This preparation also happens to be the procedure for upgrading a Cisco IP phone firmware.
Follow the steps below to successfully factory reset your Cisco 7942, 7962 IP phone:
  1. Unplug the power cable from the phone and then plug it back in. The phone begins its power up cycle.
  2. While the phone is powering up, and before the Speaker button flashes on and off, press and hold #. Continue to hold # until each line button flashes on and off in sequence in amber.
  3. Release # and press 123456789*0#.
You can press a key twice in a row, but if you press the keys out of sequence, the factory reset will not take place.
After you press these keys, the line buttons on the phone flash red and the phone goes through the factory reset process.
Do not power down the phone until it completes the factory reset process and the main screen appears.
Oct 10, 2014 | Cisco 7942G IP Phone
Cisco 7972 use headset
You can use a standard PC or cell phone headsets with Cisco phones. With help of our adapters, you can convert computer headset, smartphone headset or cordless phone hands-free into Cisco compatible headset.
Cisco IP Phones
Feb 06, 2014 | Cisco Computers & Internet
Cisco expert
I think you're confused. IP Communicator is the unified communications client (IM and Phone) It is looking for a capatible headset so you can use your softphone. This software is not your VPN client. There are two different cisco product: one for your VPN and one for your phone. If you're trying to ocnnect to an old-style Cisco VPN, your IT dept will have to configure that with a certificate.
Solution from Cisco: http://www.cisco.com/en/US/products/sw/voicesw/ps5475/products_tech_note09186a00809b6c40.shtml
This behavior is observed when a user attempts to install or use the IP Communicator on a system that has different names for the Playback (wave out) and Recording (wave in) devices.
In order to overcome this problem, perform one of these tasks:
-Use a USB headset that is recognized by the IP Communicator.
-Upgrade to the latest version of the IP Communicator
Nov 07, 2013 | Arris SURFboard SBG900 Wireless Router...
Oct 14, 2012 | Cisco 7942G IP Phone
My Headset does´nt have dialtone, I was connecting to cisco phone 7941, 7970, 7911, and nothing, not work.
You can use a Plantronics S11 headset with a Cisco phone, however it is not the best compatible solution. To use an S11 with a Cisco phone, you have to make sure that you are plugging it into the handset receiver jack and not the headset jack. You will need to lift the handset receiver, set it off to the side, and then hang it up after each call. If you want a more compatible solution that you can plug into the actual headset jack and just press the headset button on the telephone to answer and hang up, then you would need one of the Plantronics "H-series headsets" with the Plantronics Cisco direct connect cable ( model 26716-01 ).
Plantronics 26716-01 cable
Plantronics H Series Headsets
Good luck from Headsets Direct!
Aug 12, 2010 | Plantronics S11 Headset
Switched from Cisco phone to Avaya phone. Do i
Do you have the cord into the headset port on your phone?
Sep 24, 2009 | Plantronics Voyager 500A Deskphone Adapter...
Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Mar 21, 2008 | Plantronics PL-CS55 Wireless Headset
Cisco 7942 Phone - CP-7942G Logo
15 people viewed this question
Top Cisco Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Cisco Radio Communication Expert? Answer questions, earn points and help others
