Fan runs, cooling and heating do not.
Wife heard a loud popping noise just before it stopped cooling/heating. Fuse was tripped. When reset fan runs, cooling and heating do not. Has not retripped the fuse.
  • adair_s Jun 15, 2009
    it is an electric window unit. It is an A?c & heating unit.
  • Aaron May 11, 2010
    Is the furnace gas, electric, or oil. Is the outdoor unit an a/c or heat pump?
    Problem Solver:
  • 16 Answers
Sounds like capasitor blew, or bug or snake or someyhing got into compressor area if outdoor heatpump or unit, could be snails also. if so might have killed compressor or something else electrical
Posted on Jun 15, 2009
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Why does air conditioner trip circuit breaker?
call the technician
indicates a compressor problem
could be a failed start/run capacitor or compress failure
Nov 19, 2017 | Heating & Cooling
Noise and burning smell from heater
Yeah.
Pine needles get into the heater box and clog the heater fan motor's "fan".
You also may have rodents in there,making nests.
The wife was smart to turn off the heater fan B-4 the fuse blew.
Feb 21, 2013 | 2006 Toyota 4Runner
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Fan wasrunning heard aloud humming noise now the fan stopped
you could be lucky and the bushes have worn out. else its probably burned out.
AndystUK
Sep 02, 2009 | Hampton Bay 48670 Flemish Pewter Finish...
My radiator fans both have stopped working
Could be a few things. If your fans were just working then just stopped, it could be the fan motor. It could also be the relay. If you know where your lo speed and high speed cooling fan relays are located, you can eliminate this step easily. Take a known working relay (rear defrost or something not essential for starting) and replace the fan relay with the known operational relay while your engine is running and A/C is turned on. If the fans start, there's your problem, if not, then it's probably your fan motors.
Make sure the fuse that protects the fan speed relays is not blown as well.
Jul 06, 2009 | 2002 Mitsubishi Lancer
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Jun 03, 2009 | Sony Computers & Internet
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
