Question about Husqvarna Garden
Husqvarna cth210xp how to remove the electric clutch
2 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: How do you remove the electric clutch from a
Remove the primary belt and mowing deck to give yourself some room to work.
Locate the wires from the clutch and follow them toward the frame until you find the plug and unplug it.
Remove the bolt and washer from the center of the clutch going up into the engine crankshaft and slide it off the shaft. It is quite heavy so be careful when it comes free.
Posted on Sep 23, 2009
Why I can't keep the electric clutch engaged after 10 minutes when I first start cutting.
sounds like you have a frayed wire going to the clutch . it too should be 12 volts full time .
Jul 23, 2015 | Husqvarna Garden
Why is it when electric clutch is engaged, engine cuts out?
Most likely the seat switch is either bad and unplugged.
Jul 31, 2014 | Husqvarna Garden
How to release the electric clutch
it shouldnt need to be released as soon as power is cut to clutch it opens and shuts off if it stuck together your bearing are gone remove it replace with new one sorry good luck
Jul 13, 2014 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
How to replace clutch on yth2348
it should just slide off after removing the center bolt
Sep 02, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Can't figure out the stack sequence of the belvue washers within the clutch/drive plates on my Husqvarna Electric 16 chainsaw so that the housing fits properly
First to go on is the sprocket, this is followed by the thick washer, then the first belville washer convex down, then the next one concave down, then the final one convex down, then the silver washer and finally the allen screw.
Oct 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Remove blade clutch from a Husquavrna 4817iz zero turn more.
Remove the footrest. Apply pressure to the belt tensioner to loosen the belt, slip the belt off the pulley opposite the tensioner. Remove the belt from around the electric clutch. Unplug the electric clutch (2 pin connector With a socket wrench, remove the bolt in the end of the crankshaft which holds the electric clutch in place (you may need a piston stop or other device to keep the engine from turning in order to do this), then remove the clutch. Installation is the reverse of removal
Oct 25, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How do you remove the electric clutch from a Husqvarna riding mower?
Sep 23, 2009 | Garden
Husqvarna chain saw clutch bearing removal
you need a specal tool to remove the clutch assy.it grabs the clutch assy. and you spin it reverse thread.most shops will only charge you a couple of bucks to remove and install it if you have the parts
Feb 21, 2009 | Husqvarna Garden
Garden Logo
18 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
