Question about Microsoft Computers & Internet
How to go to Control Panel of windows from the Passport POS system.
I want to add printer to the pos system.
  • 77 Answers
Dear open run and tpye control then enter control panel will be open
Posted on May 01, 2014
4 Suggested Answers
proartya8765
  • 581 Answers
SOURCE: RE: pcamerica RPE POS How do
when you go to print you will see an option box with one of your printers in it and a small triangle to the right of the box. click on this and you will have the option to select the printer you want for your priint job. If you want to always use this printer (until you change your mind) set it as the default printer and all your print jobs will go to it automatically to do this go to Control Panel and select printers or if you are using Windows 7 it is under Devices and printes. click on the printer you want to use and set it as default.
Posted on Dec 31, 2009
issken
  • 1472 Answers
SOURCE: WE LOST ELECTRIC POWER. NOW
vicsmoonlove
What it sounds like is your network did not start up properly after the power outage.
So what you need to do is turn off all your computers and then reboot any routers or switches you have. After they have been up for about 1 minute then turn back on the computers then you should connect properly.
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
Posted on Sep 05, 2010
geswinde479
  • 165 Answers
SOURCE: Do you know anything about Aloha POS System and
Touch screens belong to a new generation of computers that replaced the type keyboards. Usually touch screens are effective to retail transaction requirements. Observe at the retail stores that function resourcesfully with prior prorgamed buttons as acqtion keys. For example, a touch screen transaction system overrides the requirement to typing a request for products either as details. Usually the touch screen device monotor has prior prorgams that allow button pulse responde were an entire prior programs is requestble.
Posted on Feb 19, 2011
How to find POS System for iPad suppliers?
Hi William. You can get POS for ipad but you will limit yourself to only a few as probably 95% of POS is Windows based due to simpler software, cheaper machines and MUCH larger touch screens with more products on them. Also, you have to buy more expensive (and sometimes unreliable connection) wifi or ethernet printers as the ipad has poor connectivity (no sockets to plug devices in). If you are still keen, check what is available in your area on Google using keywords such as POS, ipad and your area. Hope this helps
May 30, 2016 | Retail Supplies
Pos terminal no connection to printer
Randy, happy to help you brother, first things first!
Okay lets break this down in simple steps! this sounds like simple Networking issues, due to not printing and being able to use the credit cards features.
Is your POS in the same Network range? usually a network consists of 192.168.ZZZ.1 ( Z being a numerical example) all the way to 254. if your other pos is for example to say 192.168.0.80 then this pos has to be ALSO in the same range but with a different IP lets sayyy 192.168.0.81 or which ever is not in use. let me send you a link with the instructions on how to change an IP> https://www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/
if your connected to the same network, and you still can't do anything and your ip is correct, then this means that you have another equipment with the same IP as the POS this is called an "IP Conflict" simply change the IP of the adapter and your gonna be good to go.
if everything is perfectly fine, then restart the "Printer Spooler" service within the machine to be able to print and contact the printers. attaching the link aswell http://www.dell.com/learn/us/en/05/videos~en/documents~esupport-start-restart-windows-print-spooler-eng-ver1.aspx
i hope i have been able to help you!
Sep 18, 2017 | Logic Control Computers & Internet
My bixolon SRP 350PLUSII is double printing one receipt, please help me how to solve it
There is no option that I know of, on the printer to do this. I suspect this is an option in the pos software that you are using. If you are using windows try doing a test print to the srp350ii from the printers in control panel and see if it prints once. I am pretty sure it will and that will prove that it is something in the software itself.
Oct 25, 2012 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have replaced a posiflex receipt printer with a Problem with the POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer I have replaced a posiflex receipt printer with a bixolon...
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
Jan 03, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Wrong kind of firmware to download cds.What do i do?
go to add and remove icon in control panel when loaded scroll to name of firmware then remove it ie uninstall it
hope this helps
Jun 04, 2010 | Microsoft CompuRegister POS-1000 POS...
Is it viata ready or what os do i need for epson tm-u220pb printer
The requirements for epson tm u series printers are.....
Windows XP, Windows 32bit: Microsoft Windows XP Professional 32bit SP3 English, Microsoft Windows XP Embedded 32bit SP2 and Microsoft Windows Vista Ultimate 32bit SP1 English
Windows 64bit: Microsoft Windows Vista Ultimate (x64) SP1, Windows Server 2008 Standard (x64)
Aug 10, 2009 | Epson TM-U220PB Matrix Printer
Suremark 4610 on Sure POS system/ Laptop T23
We specialize in these products.
Capital Computer Group
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
Wethernb@capcom-ncr.com
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Jan 14, 2009 | IBM 4610 TG4 Thermal Label Printer
IBM POS and QuickBooks POS
wow...let's see what's up with this...so, you need drivers for that printer..what windows version you on?
Mar 17, 2008 | Computers & Internet
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
