Question about Vivitek H1080FD DLP Projector
When i power on h1080 projector the on led is flashing
H1080 projector not startin. When i power on the projector, the 'on' is flashing blue and projetor not starting
Viewsonic projector Pro 8200 will not start / get out of standby mode
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | ViewSonic Office Equipment & Supplies
I hav e a vivitek 1080hd projector and it turns on for a couple of seconds then shuts off. it blinks a code of 62. 6 blue blinks of the power button then 2 red blinks of the ready button
That code indicates a fan-2 error. These projectors generate a lot of heat and depend on air circulation to keep everything cool. Make sure nothing is blocking the vents on the projector. Check the fan for lint and dust. Make sure fan spins freely and is operating correctly. Keep projector away from any other heat sources. Hope this helps.
Jan 01, 2014 | Vivitek H1080 H1080FD DLP Projector -...
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
Projector won't turn on and LED Temp/Lamp flashes! has new lamp
I wish you had received a relevant answer to your question, as I'm experiencing exactly the same thing here. Not sure is this site notifies people when they get responses, but did you ever figure out what the problem was?
Apr 08, 2010 | Optoma MovieTime DV10 Multimedia Projector
The bulb will not turn on but the power light is shinning blue but the front yellow power light is flashing
still in cooldown mode. if you turned it off or unplugged it before it completed the cooldown process, it'l go back into it for as long as it's timed to. let it run for a few minutes and wait for it to go off. if it still doesn't light, you have a ballast issue.
Oct 24, 2009 | BenQ CP220 Projector
Projector lamp not switching on
Hi Altus
Wich country are you in ? I can try and direct you to a repairer for this faulty Mainboard.
Apr 29, 2008 | LG PREMIER - RD-JT50 RD-JT52 - AJ-LT50 DLP...
Flashing leds no picture
when You changed the bulb  you have to reset the bulb timer , that why the light is flashing red , look at your manual and reset the timer , and the picture , changed bulbs myself before i found what the problem was ,
Mar 25, 2008 | Sharp XR-10X Multimedia Projector
Vivitek H1080FD DLP Projector Logo
Top Vivitek Office Equipment & Supplies Experts
Miguel Luiz Martins
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
