Question about Black & Decker Scroll Jig Saw Blade
Screw to keep blade in
Two screw keep the blade in
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
The blade on my jigsaw keeps flying out when i try to cut wood ive inspected the the place where the blade goes looks ok please help
There are diffrent blades for difrent makes ,Did you by the correct make e.g if its bosh by bosh blads .The slot might also be worn out if you used the wrong blade in it or the screw that holds it in is warn ,Hope this helps
Oct 01, 2014 | Saws
Blade screw keeps turning when trying to replace blade
remove the power lead from the wall socket
put a screw driver in the teeth of the blade and use it as a stop against the guide
use the right size spanner and undo the blade retainer nut
Aug 21, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
Reattaching the blades
The blade (the small one with several holes) gets attached to the slide spring (the thin pieces of metal with a small gap between them), through the two diamond shaped holes, with tension on the slide spring keeping the blade in position. The blade guide, the large plate with only two holes, gets mounted with the two screws. The rough surfaces of both blade and blade guide face each other.
The two screws of the blade guide are tightened completely. Adjust the tension between the blade and the blade guide with the large plastic screw on the side of the trimmer (this allows the blade to move rapidly from side to side). I plug it in at this time and when the cutting blade begins to move the clipper makes much louder noise. This is normal but it sounds like it is broken, it isn't. Adjust the cutter slightly past movement. You don't want it to bounce on the guide.
Feb 21, 2011 | Oster 78950-100
I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE BLADE, BUT I'M NOT SURE EXACTLY HOW TO REMOVE THE BLADE GUARD. I KNOW THAT I NEED TO PURCHASE THE CORRECT BLADE WRENCH TO DO THE JOB. CAN YOU TELL ME THE...
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Dec 31, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Dec 26, 2010 | Andis Improved Master Hair Trimmer
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Can't get the blade to stay on track
There is an adjustment you can make to the top guide wheel to make the blade stay on track. There is a screw with a lock nut just beneath the main bearing for the top wheel that is used to "tilt" that wheel to allow the blade to stay where it is suppose to. This needs adjustment periodically due to normal wear in the bearings or maybe due to a blade which is made a little different than the last one that was on there. Loosen the lock nut, then turn the adjusting screw to tilt the wheel in the direction needed to keep the blade on. Not much adjustment is usually needed. After turning the screw, jog the motor on briefly (with the blade on) and check how it runs. Keep adjusting until you get it running true. Lock the nut and you should be good.
Good Luck. Be Careful while jogging the motor to check the runout, as you will need to do this with the guards out of place.
Dec 09, 2009 | Northern Industrial Tools Electric Meat...
Jigsaw dc330 blades keep poping out when used
Hi Paul,
When inserting the blade, turn the saw upside down to prevent the blade from moving while tightening.
Before inserting a new blade, check the receiver for obstruction or debris that may prevent the blade from properly registering with the tightening screw.
Make sure the blade is fully seated in the receiver before tightening.
The tightening screws that secure blades on any type of reciprocating saws (Jig, Scroll, Sawzall, etc.) are constantly under stress and do wear out. If the problem continues, it may need to be replaced.
Best regards
Mike
Oct 29, 2009 | Dewalt Saws
The blade keeps rubbing with the upper part of the machine
Make sure the orange blade is properly seated and screwed in place. Don't screw it too tight though. If it still touches the top cover, sand it off or file it off. Whatever the blade touches the white portion of the cover, file it off.
Oct 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Black & Decker Scroll Jig Saw Blade Logo
77 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
