Question about Compaq Presario M2000 Notebook
Blank screen on start up
When i turn on my prsario m2000 it turns on shows the compaq logo beeps twice then goes to black screem that says f1 to resume or f2 to setup help
  • 1,006 Answers
Re: blank screen on start up
If the system can't detected hdd then ur hdd is damanged and just buy new sir
Posted on Oct 30, 2007
  • 327 Answers
It means that your system cannot detect Windows on your hard drive. Check the connections inside if you can. If everything is connected properly, then your hard drive is probably is at fault. You can do a disk check in dos but may not be accurate.
0 characters
3 Points
Hi i have a compaq presario laptop and after it stars up the screen just goes blank
do you still see the compaq logo and does it show you the windows boot up screen before it goes blank?
do you see anything on the screen at all after pressing the power button?
Check if the laptop is receiving power. If it has power and you can't see anything on the screen it could mean that the LCD assembly or the Video card of your laptop is bad.
If it goes to the compaq screen and then to windows logo before going out, try booting into safe mode and once there uninstall the video driver from the device manager because that means the resolution was set to something higher than the display could handle.
If it restarts after showing the compaq screen try reseating the memory, hard drive and wireless card of your computer put them one by one and try turning the compter on after each part you put back to check which component is point of failure.
Otherwise you have a bad motherboard and it may have to be replaced.
Hope this helps!
Jul 27, 2011 | Compaq Presario 700 470024-192 Notebook
When i turn on the power it beeps twice but the screen stays black
OK, have a look at the link below, let me know exactly what beep code you are having.
Click HERE.
After we have determined what code you have. We can start working on a solution.
Kind regards
Sep 21, 2010 | Compaq Presario M2000 Notebook
Laptop shows Toshiba Logo, then Bios option, and then goes black
yes its very possible maybe the one u replaced was faulty?
Apr 08, 2010 | Toshiba Satellite P35-S611 Notebook
Computer starts up to a blank screen
Feb 12, 2009 | Dell Latitude D630 PC Notebook
Cant See Post
The 2 beeps are an error code. It can mean a couple of things; 1. Bad or improperly seated RAM; or 2. Bad or improperly seated video card. The F2 option will take you into bios setup. But I would try the video card option first as it is the usual culprit in this situation. Hope this helps & please rate this solution fixya. Thanks.
Feb 06, 2009 | Compaq Presario M2000 Notebook
Trying to reformat my PC but can't get into BIOS set up.
Seems the screen is slow to start up, right after pressing the power button, keep tapping on f1 or f10 untill the bios screen or something else comes up. that will definitely get you into the bios and dont mind if the computer starts to beep, slow down a little and keep tapping.
Aug 30, 2008 | PC Laptops
Compaq presario will not come on
Hit F-8 and start in Safe Mode, do you have the back up cd's, let me know
May 29, 2008 | Compaq Presario M2000 Notebook
Compaq M2000 beeps twice
Try powering it on without the battery in (with the power plugged in). Are the results different?
Dec 06, 2007 | Compaq Presario M2000 Notebook
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario M2000 Notebook Logo
272 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
