Question about Nordic Track C900 Pro
Incline does not work
Incline does not go up and down
Pftl788071 incline
Sounds like the button on the panel is stuck somehow, I think this because when you switch the wires this would reverse the polarity to the incline motor.
can you tell if the panel is recognizing the pushing of the incline buttons, like with a beep or light or something? If it didn't seem like it's responding this may be because one button is constantly stuck down.
Apr 14, 2014 | Proform Exercise & Fitness
The incline is stuck in the highest position
Try recalibrate. If that dont work, replace the incline motor.
  1. Press speed^ and stop simultaneously
  2. Insert key
  3. Press stop once
  4. Press Incline up
  5. (This should recalibrate incline). If this fails, replace the incline motor.
Dec 31, 2013 | Proform Perspective Es Treadmill PFTL99806
Treadmill incline not work
Run please the software calibration for easy diagnostics+and fix it.
God bless you
Jul 06, 2013 | Exercise & Fitness
Continuous incline with no lights on display except 2 lines on the incline
RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
God bless you
Sep 04, 2012 | Icon Epic T60 Treadmill
My Tunturi j800 is stuck in the incline position. Other than that, it works great! How can I get it down? The screen reads that it's at 0% incline.
RUN THE SOFTWARE CALIBRATION FOR DIAGNOSE, TROUBLESHOOTING AND FIX IT.
2) you can lube the gear, shaft+ adjust the potentiometer+see the relais contact are clean it.
sincerely. God bless you
May 02, 2012 | Tunturi Exercise & Fitness
Incline motor stays on going down, and will not respond to the controls. healthrider R 60
could be bad incline sensor or c/board is going bad. one more try bipassing the board with power to the incline motor fully powered 18volt batt will or higher will move the motorby flipping thr wires on the bat the incline should go up and down. if working ok then check board
Mar 16, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
I have an Epic t60. The incline stopped working. I was in the midst of going from flat incline to full and then back down again when it stopped. The incline numbers now register on the display, but it...
Try to recalibrate the incline. Start the machine running, press the incline up button, then pull the safety key off. Release the incline up button and replace the safety key. The treadmill should go to maximum incline then minimum. after calibration is completed, retry the treadmill operation.
Jan 11, 2011 | Epic Overstock T60 Treadmill Treadmills
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Apr 28, 2010 | Life Fitness 9000 Next Generation...
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordic Track C900 Pro Logo
70 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
