Question about Mio Cyclo 305 HC
History mio 305
Histore
My garmin edge 305 will not upload my rides, the training center software stalls at 2% the declares an error.
I have similar problems that have only just started.
Together with Training Centre crashes after uploads forcing rollbacks by deleting a history tree file and using a backup...
Tres frustrating...
Am thinking seriously of ditching it...
Nov 29, 2010 | Garmin Edge 305 GPS Receiver
How do you transfer 305 history to a new computer?
If you go into the Garmin Training center software under "File" you should see "Export". On some versions there is a Back up as well.
If you go into the Export and Export everything, Work outs, History, and Courses (all seperatly) you should be able to save these files to a USB stick. Using the USB stick you should then be able to "Import" these files to the new PC. Obviously you will need to install the Training Center onto your new PC first.
Feb 06, 2010 | Garmin Forerunner 305 GPS Receiver
I have a new Forerunner 305 and it transfered my first workout to the computer but will no longer do so. The device says "Transfer Complete" however the computer states "There was a problem communicating...
I've just experienced a similar issue for the first time since owning my Garmin 305 Forerunner. Slight difference in my circumstance is that the device itself doesn't show the activity in its history, despite having displayed apparently accurate readings during the activity iteself. Bizarre isuee, and although it's my first issue with this otherwise great device, it does destroy your faith in the unit.
Nov 08, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin 305 stops uploading data
Try maybe a different computer and see if it works. If it doesn't then something is wrong with your item. Clearing the history won't help.
Aug 21, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 miscalculating ascent and calories
Firstly, the ascent and descent are only approximate, and can be very approximate! This is because it's using GPS to calculate your height above sea level when GPS is really only accurate for position Lat and Long. When calculating height, a very, very small error can lead to a large variation in actual height. You should never use a GPS for height if needed for navigation (ie climbing walking etc) If you need accuaracy you will need to get a barometric altimeter.v
As for calories, I think you have identified your problem, it's calculating calories on running not cycling. Not sure what the answer is as I don't know what software you are using but if you are using Garmin TC, bin it and use SportTracks. Takes a bit of getting used to but to really get the best out of your 305 this is excellent software and it's free. Any anomolies like your calorie issue/wrong category import can be changed manually plus a whole host of other stuff. Garmin doesn't even let you edit activities - crazy.
Apr 04, 2009 | Garmin Forerunner 305 Personal Trainer...
Garmin Forerunner battery replacement
It's not always the battery, I assumed it was and opend mine up to check it out but the battery was OK.
Problem was the unit wouldn't start without pressing mode + reset followed by the power button.
I lifted the internal watch contact strips to put a better connection between the two halves but that made no difference.
I found that I couldn't delete all the history and the watch had recently turned itself off on a run after giving a low battery warning => the history was corrupted and caused the watch grief.
The only way I found to delete the history was to load a v 2.80 (or earlier) version of the watch s/w (current 2.90 doesn't delete history and there is no tool to do it!)
Fortunately I had a copy of v2.80 but the old version is not now on the Garmin site (that I saw).
Moral of the story, don't run your battery low for two reasons, Li-ion batteries lose capacity if you run them below ~30% and also if the watch "low battery" turns off while recording it can corrupt the history and really upset the watch.
At least I now know how to open the watch and have found plenty of possible small mobile phone batteries that will fit (Samsung have a few possibilities). The ABSOLUTE max size of a replacement battery is 36mm H x 43 mm wide x 5.8 mm deep.
If you go 43 mm wide you have to trim a couple of internal plastic ridges in the case.
Good luck and try starting after pressing mode + reset if it won't fire up then try and delete all the history.
Also DON'T run the battery low if you want it to last, Li-ion work opposite to NiCad and NiMH which should be fully discharged before recharge. You try and keep them above 50%.
Steve
Sep 20, 2008 | Garmin Forerunner 305 GPS Receiver
Mio c220/c230
you have to delte all or none, no in between
Aug 19, 2008 | Mitac Mio C220 GPS Receiver
Date not changing
After my ride I needed to stop the timer and reset the device. Then connect to the computer and download the history. It appears that that information I was downloading was from a previous ride.
Jun 26, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 Uploading
You can configure the history hold duration. The user manual has simple explanation that you can browse at the link below
http://www8.garmin.com/manuals/967_OwnersManual.pdf
Similar issue I have encountered and I followed instruction on page 45, it resolved. Hope you will resolve the issue as well
Good Luck
Feb 08, 2008 | Garmin Edge 305HR GPS Receiver
Mio 220
address automatically gets saved in history. can't save POIs.
Jan 18, 2008 | Mitac Mio 168 Pocket PC
Mio Cyclo 305 HC Logo
27 people viewed this question
Top Mio Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Mio Exercise and Fitnes Expert? Answer questions, earn points and help others
