Question about Sony VPL-CX61 LCD Projector
How can vpl-cx61 sony projector to get an HD signal?
The manual says it is compatible with 1080i. It has composite vodeo thru an RCA pin jack
    New Friend:
  • 15 Answers
1080i should need HDMI Or DVI port and check ur manual as ur projector native Resaluton is 1920*1080 !!!
Posted on Aug 20, 2012
4 Suggested Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Posted on Feb 13, 2010
AJIN G
  • 6694 Answers
SOURCE: Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Posted on Dec 20, 2010
Testimonial: "Thanks! And please tell me where is the lamp cover located."
How to plug protron 20 lt20c1e1 into hp pavilion laptop
plug protron 20 LT20c1e1 as i ask my kid long ago, animal mineral vegetable.
answer, mineral.
or partly veg. with fossil fuel plastics sure.
ahhhhh google said its an LCD TV. TEEVEE or TELLY
so what are the jacks there?, I cant see em.
seem you lost your manual that it?
no Pavilion model stated. my guesS VGA jack there 19pin D-shell.?
in what country, TV not same world wide, a fact.
omg obscure TV it is.....
20" TV is super old and tiny.
looking a 26" manual
there is no HDMI
no VGA
shows connecting to PC with adapter types.
1: COMPOSITE VIDEO RCA TO vga ADAPATER
2: sVIDEO JACK TO vga ADAPTER. WORSE QUALITY
SVIDEO IS 4 PIN ROUND DIN JACK.
#1 IS BEST
there is 3 RCA jack video, and 1 audio COmponent jacks.
and 2 cable (composite ) one is vid other is sound.
sound is 3.5mm phone jack.
i cant see the side of your tv
nor see what the words are on each jack
and the manual is ,impossible to find.
Jan 07, 2018 | HP Computers & Internet
How to hook up my HDMI it don't have one to watch TVhow to hook up HDMI Akai plasma display model pdp4290
You'll need a HDMI to composite converter. You'll have to connect this to your Component 2 inputs as it's rated at 480p/720p/1080i.
(component 1 is only rated 480i/480p)
You may also need to connect the speakers with a separate RCA jack connectors.
Nov 28, 2016 | Akai Televison & Video
Pyle troubleshooting
The projector has built in speakers.
Aug 06, 2014 | Pyle Home PRJHD66 1080i Front Projector
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
Connectivity
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
    Component,
    Composite
Jul 14, 2012 | Samsung PN50B650 50-Inch 1080p Plasma HDTV
I would like to connect the audio from my Comcast DVR via digital optical thru the TV/SAT IN optical on the receiver at the same time I have a composite connection via the TV RCA composite jacks. ( This...
I'm a little confused by your use of 'composite' with audio, as in "Does anyone know what would happen if I ran both composite audio and optical audio both to their respective TV/SAT IN input jacks on the STRDE935 ?". What is composite audio?
The manual claims on page 48 that you can't record digital audio out to the analog REC OUT jacks.
http://www.retrevo.com/s/Sony-STR-DE935-Receivers-review-manual/id/387dj981/t/1-2/
I say 'claims' because the engineers or manual writers clearly are not as creative as you are in trying to wring as much utility out if this unit as possible.
I can't find an answer but I would offer this - if you are recording anything though any AVR, as soon as you choose to monitor the audio the digital input is usually disabled.
And I would be curous to hear more about what you're doing and how you finally achieve it.
Dec 25, 2010 | Sony STR-DE935
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Digital or not????
You can get the owner's manual at;
http://www.bottomlinelcds.com/manuals/PLTV-32CM-owners-manual.pdf
You need a converter box.
Specifications
General
Dimensions
33.07"W × 25.83"H × 9.09"D
Weight 45.54lbs
Panel Type Active Matrix TFT LCD
Screen Size 32" widescreen (16:9)
Color Range 24 bits (16.7 million colors)
Max. Resolution 1366 × 768
Pixel Pitch 0.51075mm (H) × 0.51075mm (V)
Sync Range Horizontal: 30–80kHz
Vertical: 50–85Hz
Contrast Ratio 800:1
Brightness 500 cd/m2
Viewing Angle Vertical: +/–85°
Horizontal: +/–85°
Response Time 16ms typical
Inputs 2 × progressive scan component video (RCA)
3 × composite video (RCA)
1 × S-Video
6 × stereo audio (RCA)
1 × SVGA (15-pin D-Sub)
1 × stereo audio line in, 0 dBV nominal (1/8" TRS)
Outputs 1 x composite video (RCA)
1 × stereo audio (RCA)
1 × subwoofer (RCA)
1 × headphone (1/8" TRS)
Video Formats Supported SDTV: 480i
EDTV: 480p
HDTV: 720p, 1080i
TV Tuner NTSC-M, CATV, 181 channels
TV Audio Mono, Stereo, SAP
Parental Controls V-Chip (TV PG, MPAA)
Picture-In-Picture PIP, PBP
Closed Captioning CC1–4, TEXT1–4
Speakers 2 × 10W
Plug and Play Compliance VESA DDC1, DDC2B
Power Supply 100–240VAC, 50–60Hz
Power Consumption Operation: 232W
Standby: <3W
Storage Temperature 0 to 60°C
Operating Temperature 5 to 35°C
Apr 08, 2009 | Protron PLTV-32 Television
How do i connect cable tv to my dell 2200mp projector
You can connect it directly with a composite cable. There would be a RCA(yellow) video output on the back of your cable TV. This is then connected to Video input(yellow) f you projector.
If your cable TV has Component output (threr RCA cable Green, Red, Blue), then these thre RCA could be connected to the similar one available on your Projector.
You could connect your sound als o thru the RCA out of Cable TV and input of Projector. But if you have a good AV Receiver or a sound system then it best suited for it, since the projector speaker is mono and only 2Watt output.
Let me know if there are any specific inputs required
The Dell 2200 mp projector has the following compatibility
:HDTV: 1080i, 720p
EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes
Mar 03, 2009 | Dell 2200MP Multimedia Projector
RCA D52130 52 in. Won't Display High Def
Hi!
I doubt you'll look at this 2 years later, or even have the T.V.
I have the same TV and was able to view ps3 and xbox 360 games in 1080i, but it's a little tricky. First, let me say that the ps3 is probably not the best system to try using 1080i in unless you have a 360 to help trick the tv into working.
Xbox 360
You need to first set the video to 1080i. This will make the screen display in a bunch of horizontal lines most of the time, but if you keep toggling it on and off, it eventually works. To avoid having to sit and swap between the two modes, it's easier to first set it to 1080i and confirm the setting, then go back into the settings, select 720 (first option above 1080i) and cancel as soon as the video mode changes. 95% of the time this will make it display correctly in 1080i mode. If you turn the tv off and back on, it will sometimes reset to the horizontal lines. If you restart the xbox, it will reset to horizontal lines most of the time. With the ps3, you can set it to 1080i and keep toggling it until it works, but when the game launches it can screw up again, so it's best to have the xbox on and ready with a component switch so you can fix it with the xbox then switch back to the ps3. I think the cable that comes with the tv for HD input (the component plugs don't work, they only support 480, but the vga looking input supports 1080i) - the cable is just poor quality and can barely handle the signal. I've been trying to find a better quality cable with no luck.
Hope this helps other people with this ancient beta HD input canadian tvness.
Dec 30, 2008 | RCA D52130 52" Rear Projection Television
No OSD on TV connected thru composite video (Monitor Out)
hello you need the s-video/sound usually four pins in each end connect to s-video not composite video..saludos
Nov 22, 2008 | Onkyo TX-SR606 Receiver
Sony VPL-CX61 LCD Projector Logo
100 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
