Question about Bosch Nexxt WTMC3521UC Gas Dryer
Kenmore 110.74832400 dryer runs but no heat is coming. I removed the back panel from the dryer and I can see the glow from the ignitor but there is no flame. When the dryer is first started the flame is present but shuts off and never comes back. Again I can see the glow from the ignitor several times during the drying cycle, but it seems like the gas does not make it to the chamber.
  • 331 Answers
The solenoid is going bad on you. there should be two on the bottom by the front of the machine... gotothis site www.techray1.com and click on the guru guy on the left. this will take you to the site where it will sell it to you cheap and installation instructions
Posted on Jun 15, 2009
The dryer spins but the burner does not always ignite.
Hi the most likely cause for this is a weak or failing ignitor. Remove the bottom front panel and observe with dryer running. If ignitor does not glow test it for 120vac if you have 120vac replace ignitor. If it glows but does not ignite the you ignitor is weak replace it.
Nov 03, 2010 | Kenmore Dryers
Igniter does not come on.
most probably a faulty ignitor.  check the thermal fuse also.
Jul 08, 2010 | Kenmore Elite HE4 Electric Dryer
No heat,vent clear if i remove toe panel can i see ignitor how do i remove toe panel?
check thermal fuse in back near exhaust. or on top of burner tube. if your dryer has a toe panel there are 2 clips on either side at the top that you can release with a putty knife. if no panel you have to take off the whole front. If ignitor glows and no ignition replace the valve coils.
Jun 15, 2010 | Kenmore 75962 Gas Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Dryer won't heat up
HI, Can you see the ignitor glow at all? If not, check the thermofuse first. It is located on the blower housing white, /4" wide, & 3" long. If you can remove the rear panel on your model, that is where the fuse is located. If you can not remove the back panel, some models you have to remove the whole front panel and some the lower half front panel comes off.
If the ignitor does glow, you will need to replace the coils on top of the gas valve.
I hope this helps. Please let me know if I can assist you further.
Vic
May 19, 2009 | Dryers
Kenmore series 80 gas dryer not heating
Replace this fuse
Check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 10, 2009 | Dryers
No heat.
yes they should be able to test it for you off of the dryer
Apr 14, 2009 | Dryers
Kenmore gas dryer series 80 not heating up--dryer revolves but no heat--guessing it's the ignitor--can't access-no lower panel to open tomroske@msn.com
small plug left side bottom remove it this will allow you to see if ignitor is coming on if it is suspect the coils on gas valve or no gas to dryer if no glow possible bad thermal fuse remove back small white object on blower housing ..if no lower panel ..remove 2 screws under filter pop top 2 clips 1 each side about 2-3 inches from end..2 screws 5/16 1 each side upper corners remove lift front off
Jun 27, 2008 | Dryers
Kenmore elite gas dry 6 years old - no heat
PUT YOUR DRYER ON AIR FLUFF AND TURN IT ON. THEN SELECT A HEAT SETTING. IF YOU HEAR A DISTINCTIVE CLICK WHEN YOU SELECT HEAT, THEN CHECK FOR A GLOWING IGNITOR. MOST KENMORE/WHIRLPOOL DRYERS HAVE A PEEP HOLE IN THE FRONT LEFT SIDE OF THE DRYER. REMOVE A PLASTIC COVER TO VIEW INSIDE.
IF THE IGNITOR GLOWS, AND THEN CLICKS OFF, YOU HAVE A BAD SOLENOID (COIL SETTING ON TOP OF THE VALVE). IF IT NEVER CLICKS OFF, YOU HAVE A BAD RADIANT SENSOR( LOCATED ON THE SIDE OF THE BURNER HOUSING). IF NO IGNITOR GLOWING, THE IGNITOR IS BAD.
IF WHEN YOU SELECT HEAT, THERE ISN'T ANY CLICK, THEN THE THERMAL FUSE LOCATED BEHIND THE BACK PANEL DOWN NEAR THE EXHAUST IS BAD. IT IS A SMALL WHITE ITEM WITH TWO THIN WIRES ATTACHED TO IT.
Apr 07, 2008 | Dryers
No heat
If your dryer has an access panel at the bottom front remove it.  Start the dryer in a cycle and watch the burner area. You should see the ignitor start to glow. After a few seconds of it glowing you should hear a click and the gas come on and ignite. If the ignitor does not glow, look on the top of the air duct to the left of the gas valve. You will see 2 temp sensors. One will be white with  2 small blue wires going to it.    UNPLUG THE DRYER NOW    Remove the wires and connect them together.   BE SURE THEY DO NOT TOUCH ANYTHING ELSE
Plug dryer back in and start dryer again and see if ignitor glows and burner lights. If it works now, you need a new thermal fuse. You also want to make sure the vent duct is not clogged with lint or the hose is not kinked.  I DO NOT recommend that you run the dryer with this bypassed. It is a safety mechanism.
If this is not the problem or your dryer is not front servicable, post back and i will try to walk you through the problem.
Oct 11, 2007 | Dryers
Bosch Nexxt WTMC3521UC Gas Dryer Logo
463 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
