Question about Digital Galaxy Dg-737 Hd 1080i Hdmi Lcd Projector
Not able to change input
The input menu will not show when i push the pc/av button. I am currently stuck on the UPS input and the left and right keys do nothing on this screen. how would be the best way to change the input
I have a 2008 LG 42LC5DC. The tuner is currently set to receive a cable box feed but I'm using antennae only and want to scan over the air channels. How can I get to the setup menu?
First set the input to TV if your cable box feed didn't come in on the RF cable. Press the Input button on the side of the TV (the second button from the bottom above the Power button). Alternatively press the Input TV button on the top left of the original remote. (You'll have to search through the inputs if you have a universal remote without the feature.) Next press the Menu button on the TV or on the remote, if you have the original remote/universal remote with the matching feature. On the original remote, the Menu button is above the OK button. The Menu button is the third button from the bottom (above the Input and Power buttons). Press the Menu button and then use the Up/Down arrows to navigate to Setup. (If you use the TV buttons, the Ch Up/Down buttons are Up/Down. The volume increase and decrease buttons are Left and Right.) Press the Right arrow key and then Use the Up/Down buttons to select EZ Scan. Press the Right arrow key again. Press the Right arrow key or Enter (on the remote) to launch the scan. You can find the screen shots of the Menu options and the button locations in the manual. The manual is available here: http://www.lg.com/us/commercial/documents/32lg505h-owner-manual.pdf .
I hope this helps.
Feb 06, 2018 | LG Televison & Video
What's the imput button or code on remote for ten year old TV. Model #14MS2331/17
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: http://download.m4c.magnavox.com/files/1/14ms2331_17b/14ms2331_17b_dfu_aen.pdf .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
I hope this helps.
Aug 28, 2017 | Televison & Video
How to I change the video input? i.e. I got a digital TV box and need to put it to video input 1. How?
  • On the back of your TV are all your inputs/outputs.
  • On the far left is your Video 1 Input.
  • The top input is your Video (Yellow AV cord)
  • The middle input is your Left Audio (White AV Cord)
  • The bottom input port is for your right Audio (Red AV Cable)
  • After you have all the AV cord up as I have explained then push the "TV/Video" button on the remote until "Video 1" appears on the screen.
  • In the event you should want to use Video 2 sometime then hook the cords up the same way except in the Audio 2 port in the back of the TV.
  • Each time you press the "TV/Audio" button you will cycle through the Inputs until you come back around to TV.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Panasonic CT-32SL13 32" TV
My wife thought it was hooked to a cable box for high number channels and pushed 707 on the remote TV sig went out. TV powers up but no menu no signal just a power light and the background is on but no...
Hello
have you tried pushing 003 on the remote or the AV buttons?
All I can think of is that you must the get tv BACK ON the right channel or AV Input.
Hope you have a better day
Nov 25, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a comcast Motorola HD capable cable box with DVI output - going through a converter cable into an HDMI input. When I change from a hi def channel to a std def channed, the screen gets split, and...
Here sounds like your override setting on cable box needs to be set.
Here is how to fix that-
1. On remote push the button at the top that says CBL or Cable.
2. On remote push power button.
3. On the remote push the menu button.
This should bring up an internal menu called user settings.
4 Use the remote to scroll down to 4:3 OVERRIDE and use the LEFT or RIGHT arrow keys on the remote to change the value to 480i and see if this clears up your problem. If not repeat and change the setting to 480p and one of these settings should fix your problem.
Good Luck and please rate this solution.
Jan 04, 2010 | Panasonic TH-42PX60U Television
Camera is stuck in Japanese - how do I get to English when I cannot understand the prompts?
open ur cam then hit menu then first word u see by hiting push button on ur cam then go by same push key down on word number 3 that what means language then turn push button to right or left till it shows down english all will turn english then
Dec 25, 2009 | Vivitar ViviCam 3750 Digital Camera
Input channel with no remote
You should be able to select the AV input with an Input or Menu button on the front of the TV.  If there are no arrow keys the Channel and Volume buttons may provide up-down-left-right action.
May 28, 2009 | ESA ET427E 27" TV
Won't play sound out of the AV. 1 and 2
You probably have the av inputs set to digital instead of analog. The easiest way to fix this is to turn the theater system on, turn it to one of the the inputs, then hit menu on the remote. You will cycle through some options with the right arrow until you get to "input", which will offer av 1 and av 2, you can select either one with the ok button. then you will get some more options, analog - optical - coaxial, the first one that shows up is the one you've got currently selected. unless you're using one of the other audio input formats, the system should most likely be set to analog. You will probably need to do this with both inputs.
You have to do this every time the system loses power in my experience.
Dec 29, 2008 | Koss KS3102 System
Digital Galaxy Dg-737 Hd 1080i Hdmi Lcd Projector Logo
77 people viewed this question
Top Digital Galaxy Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Digital Galaxy Office Equipment and Supply Expert? Answer questions, earn points and help others
