Question about Jenn-Air JED8230 Electric Cooktop
How to connect 4 wire into 3 wire existing box.
    President:
  • 1,865 Answers
L1 and L2 connect to the black and red. White connects to White. Green connects to the electrical box if it is made of steel and is grounded. Otherwise the green connects to the whites
Posted on Jun 14, 2009
  • 3,600 Answers
Are you ging from a 220v 4 wire to a 3 wire? if so the ground and neutral are white and green and are one in the same, if your current system only has a two legs of 110 Volt and one ground then you need to run a ground for the forth leg. This is according to N.E.C. and depending on your location your local codes will apply. Really need more info to help you.
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
Electrical wiring
ones connecting to anther set of plugs red on postive top countuins sending power to next box in a chain
Jan 19, 2008 | Jenn-Air JED8430 Electric Cooktop
Do i connect the red and black wires together
No you do not. You have a 220 system. What you do to hook it up is. In the box in the wall you should have 3 wires. 2 black and one white. Then on the cooktop you have the 3 wires 1 black, 1 red, and 1 white. You take the black from the cooktop to the black in the wall box. Take the red to the other black in the wall box. then take the whites and put them together. Now if you have a green or bare wire that is the ground. Just hook that to the wall box.
If you have any questions please ask.
May 09, 2010 | Jenn-Air JED8230 Electric Cooktop
I need the wiring diagram and plug/receptacle specs for kenmore electric cooktp 42732
I believe that if you look on the name plate for the unit , it says that you will need a 30 amp, 220 volt supply circuit . This would be a two pole , 30 amp breaker , a run of # 10-3 cable with ground, and a junction box at the stove top location to make the splices. If you are going to use a plug connection, then a 30 amp 4 wire dryer outlet will give you the connection you need .
Apr 07, 2010 | Kenmore 30 in.42731 / 42739 / 42734 /...
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
Cooktop WIring
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the past...it will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code change....to provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Krazytech
Apr 05, 2008 | Whirlpool 30 in.GJC3055 Electric Cooktop
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
1,655 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
