Question about Bose Lifestyle 38 System
No sound coming from speakers - Bose Lifestyle 38 System
I just created my own pc. i decided to go against getting a sound card. My sound works coming from the mobo. I hear the music from my display moniter speakers. When i connect my headphones to the front...
You need to change the sound profile from 2 speaker system to surround sound. You will find this in the control panel area program.
Hope this helps.
Thanks
Jason
Oct 25, 2010 | Logitech X-530 Computer Speakers
Sound coming from only one speaker
> try to check the settings from the sound properties
Jun 14, 2010 | Insignia 2.0 Speaker System (2-Piece)
Sound comes out of one speaker
Check the wiring connections. Replace any speaker cable.
Sep 25, 2017 | Kinyo PS-205 Computer Speakers
No sound is coming from my speakers &headphone
no sound is coming from my speakers
May 18, 2009 | HP Sound Card
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Speakers sound quiet and unclear
You probably burned tweeters and damage midranges but before disasembly check equalizer
Feb 27, 2008 | Audio Players & Recorders
External speakers
I would bypass the speakers from the projector and connect the audio output from the DVD to a sorround sound system or to computer speakers.
Jan 17, 2008 | Hitachi CP-S210W Multimedia Projector
Sound not coming out of the rear or center speakers
Sort of confused a bit I understand you buying a new system you say the sound does not come out the rear and centre speakers does the sound come out of any spearkers other than the two you mention if it is then your wirings are wrong if the sound is not coming out of any speakers then its the sound card BUT you will know this immediately you disconnect that system. The sound would be coming out of the laptop ordinaryly? which is it?
Sep 04, 2007 | Logitech X-530 Computer Speakers
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Bose Lifestyle 38 System Logo
53 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
