Question about Amcor 9,000 BTU AutoDrain NanoMax Portable Air Conditioner KF9000E
Not cooling 2008 unit bought at Home Depo ST.Augustine FL. in storage for a year, compressor not kiking on ? lower the thermostat setting to 72 or 64, does the system has a Freon Valve ? took it apart clean and could not find valve. the only thing diffrent from previous use, it's that I cut the two foot length 1/4" drain hose to 10" length only.?
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
AC is just blowing air. The compressor doesn't kick on.
no freon.. pressure test w/ nitrogen. 8000 btus is now junk. Spend the money on new unit otherwise find the leak. It leaked out thats why the compressor will never go on. Once you add freon she'll turn on...same as car.
Dont buy that name brand again. best of luck to you
Aug 17, 2009 | LG Heat cool Window Air Conditioner
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
Lower unit does not cool
check for conditioned space fan not running. Does top cool and not the lower or are both not cooling properly. If fan is running, it could either be that the thermostat is not set low enough, evap is frozen up, the unit is low on freon, the compressor is not running. Start checking as much as you can and let me know.
Mar 22, 2009 | Carrier Beverage AirĀ® DP46 Commercial...
Compressor will not kick on
(1)Check if elecric power is going to the unit.
(2) Check your Thermostat setting ,set the thermostat to the lowest setting
(3) Check the digital thermostat if it is in the cool position and automatic start
(4) Check the batteries on your hand held remote change if necessary.
(5) If you try these suggestion and it does not work you may check for loose wire in the electrical circuit or a defective control board. Let me know your findings.
Mar 27, 2008 | Heating & Cooling
Westinghouse Flatscreen TV
Our Westinghouse Flat screen tv plays for a little while then turns the picture off but the sound is still on. How can we get this fixed?
Thomasville, Ga.
Jan 29, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
Aug 23, 2007 | U-Line 2075WC Wine Cooler
Amcor 9,000 BTU AutoDrain NanoMax Portable Air Conditioner KF9000E Logo
42 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
