Question about Breville Bdc600xl YouBrew Drip Coffee Maker
Breville youbrew no water coming out of tank
Machine comes on but won't make coffee
SOURCE: No water is being pumped at all
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Posted on Dec 26, 2007
  • 74 Answers
SOURCE: No coffee
Does it come out water from the steamer?
if that is the case I would clean the filter on the machine.
Posted on Jul 16, 2008
SOURCE: how do I get my breville cafe roma espresso
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
Posted on Dec 28, 2009
espressonist
  • 1711 Answers
SOURCE: Water (coffee) does not make it out through the
Propably the vibrating water pump is the problem.
It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water. Then try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Posted on Mar 25, 2010
Testimonial: "Brilliant, I cleaned the shower head as you instructed and it's working perfect, thanks for the tips. Louise"
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
Bdc600xl water will not filter through. Grinder works just fine. Checked that it was clean. Is.
The pump may be jammed. I'm not sure about these units or if the pump is serviceable. You would probably have to strip off the covers and check the hoses for blockages first then determine how the pump comes out. You should be able to hear the pump working, if not, I would say its jammed.
Aug 24, 2016 | Breville Bdc600xl YouBrew Drip Coffee...
My breville espresso machine is not sending water through the tank, how can I fix this?
Contact an Authorised Breville service agent and ask them. I doubt it will be a problem that is going to be fixed by button pressing on the outside, someone is going to need to do some dismantling to find out where the water stops.
Oct 19, 2015 | Breville BES840XL the Infuser Espresso...
No water is pumping through
Calcium build up. This can be taken care of by running vinegar through the system.
Mar 15, 2015 | Breville BDC550XL The YouBrew Glass Coffee...
My Breville BDC600XL grinder appears to be clogged and would put ground coffee into the basket. The grinder also slows almost to a stop. How do I fix it?
if this isa bed-bath and beyond unit?! take it bak!. and try the Braun coffee grinder. I hav had mine for 10 years and nevr a problem.
Dec 31, 2014 | Breville Bdc600xl YouBrew Drip Coffee...
Why won't it heat?
take it bak to bed-bath and beyond, and git another 1.
Nov 22, 2012 | Breville YouBrew 12 Cup Thermal Grind and...
Wanting basic operating instructions for CM5 espresso machine breville
there is no water coming through my coffee machine
it is a visa versa
May 02, 2010 | Breville CM5 Espresso Machine & Coffee...
How do I get my breville cafe roma espresso machine to pump water out of the water tank and through the machine? It won't create steam or brew coffee and the water level in the tank won't deplete when the...
Dec 27, 2009 | Breville ESP8XL Espresso Machine
No coffee
Jul 16, 2008 | Breville ESP8XL Espresso Machine
Breville Bdc600xl YouBrew Drip Coffee Maker Logo
1,366 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
