Question about PetSafe Venture Series Big Dog Add-A-Dog Receiver, Part No. PDT00-11952 Product Group: Remote Training Collars / Extra Collar
PetSafe 1000 Collar won't turn on after charging. Instead, non flashing red and green lights come on simultaneously for about a minute and then they go out. These lights have done this before and I was able to overcome the problem, this time I can't seem to nor is there anything in the manual on this problem. Thank you! I need this fixed ASAP!
My petsafe 1000 big dog shock collar remote is stuck on 15. I can't fix it tried everything. Please help!!
Reset your remote by removing the battery if your problem is still exist then you open your remote and tuch the up/down button base with metal (conductor) I sure it will work.
Jun 16, 2015 | Radio Communications
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
When I try to charge my headset, the indicator light flashes red instead of staying solid. Please help me, I love this headset and I'm so upset it won't work for me..
If this is not charging correctly it may be that the battery is no longer functioning properly. The batteries are non replaceable on this headset. If this is still under warranty (1year) you should be able to get a replacement
Here is a link to the User's Guide.
Good luck from Headsets Direct!
Aug 30, 2011 | Plantronics M100 Bluetooth Headset
The yard trimmer's battery won't take the charge. It charged overnight but I see the light is flashing red on the charger instead of green.
Time to replace the battery, most auto parts stores have battery testers to see if its bad or not.
Jun 02, 2011 | Garden
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
Motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Sep 16, 2009 | Motorola Mobility S9 Headphones
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Headphones change batteries
Any luck with that model number??
Apr 06, 2008 | Radio Communications
PetSafe Venture Series Big Dog Add-A-Dog Receiver, Part No. PDT00-11952 Product Group: Remote Training Collars / Extra Collar Logo
89 people viewed this question
Top PetSafe Computers & Internet Experts
David Payne
David Payne
Are you a PetSafe Computer and Internet Expert? Answer questions, earn points and help others
