Question about LG 22" Widescreen Flat Panel LCD Monitor
CANT FIND SPEAKER PLUG IN
LED 22M35
I have an Altec Lansing 340 speaker system that is not working.
There could be a defect in the connector. Check both sides for continuity.
Jan 03, 2015 | Altec Lansing Audio Players & Recorders
Headphone plug is not working
The plug on the headphone itself can easily be tested with a ohm meter at the plug end--if two black bands it is stereo, check with the meter from the section at the tip of the jack to each of the other two segments to see if continuity with each speaker in the head phone.
About the only way the socket it plugs into goes bad is one speaker will not work or it does not cut the sound out when inserted to a internal speaker if the unit has one.
Dec 19, 2012 | eMachines 15.6" Led Lcd Screenfor...
I got a mother board from a friend it a k9n6sgm-v but i can find where i have to connect my speaker-HDD LED my rest switch all the front panel
http://www.msi.com/service/download/manual-4593.html
If you follow the above link, you can download a pdf of the manual. On page 7 at the bottom you will find a diagram showing where to plug in speaker, power LED, HDD LED, reset switch etc.
Aug 16, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I cant install them?
The CA-2016 desktop 2-piece system it is a USB powered amplifier that draws the power through a USB cable. No batteries or AC power source/wires are required which leaves the desk top clean. The speaker system is magnetically shielded and has a LED power indicator. This being said setup the speakers plug in the USB cable, notice if the LED power indictor light is on. Adjust volume control on speakers and on your computer ( make sure your not muted ). PC's have a lot of different media players that can and will effect the volume control so if one or more of those items are adjusted to low volume or muted, there will be little to no output to your speakers.
Dec 05, 2010 | Cyber Acoustics CA-2016 Computer Speakers
I have a intel media series dp35dp motherboard. I have a power led cord, reset sw cord, power led cord, m/b sw cord and a speaker cord for the speaker on the chasis. When I plug them up I don't see a spot...
in newer generation motherboard the buzzer is built in in there is no need to connect an chasis speaker if built in buzzer is not there uwill find a four pin conecter near the power pannel you nedd to conect the pwer switch and reset switch in proper conector or the system wont powerup properly
Sep 25, 2010 | Intel Computers & Internet
What colors are the wires for the pwr sw, smi,rst,hdd led,grn led and where so i plug them in at s7sen 15-a01-013010 rev 3.0a
- the colors of the wires (can differ, depends on the case type):
  • Green(+ is the colored wire)-White(-) --> POWER LED (GREEN light)
  • Red-Black -> POWER SWITCH
  • Red-White -> HDD LED (RED light)
  • Blue-White -> RESET
  • Red-Black (4 pins wide)-> SPEAKER
Sep 03, 2010 | EliteGroup K7SEM Motherboard
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
Need Diagram for the pwr,reset,pwr led,hdd led speaker connections on the motherboard. Model p5s 800-vm.
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for using FixYa!!
May 27, 2009 | ASUS Computers & Internet
I cant get the HDD LED to work... yes it is hooked up right...
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Mar 03, 2009 | Gateway (4000782) Motherboard
LG 22" Widescreen Flat Panel LCD Monitor Logo
21 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
