Question about Marantz PM6004 Integrated Amplifier
Red led flashing on marantz pm6004
Please help me fix the red led flashing light on my brand new marantz pm6004.
Sky + code for Marantz PM6004?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 18, 2015 | Marantz Televison & Video
My marantz pm6004 automatically shuts off during playtime, how can I fix it?
Sounds like a heat sync problem. Open up the Amp and check for dander, dust and pet hair deposit on cooling fins, Fan and motherboard components. Air blow clean and plug in allow plenty of air circulation. You may want to even kick on a fan a blow directly on components. Be sure Amp is will ventilated and not enclosed or confined.
Dec 30, 2014 | Marantz PM6004 Integrated Amplifier
Marantz problems
The speakers are 8ohms. Always try using speakers 6 or 4ohms. For B&W 683 on PM 6004 is too low. You should go for PM 7000 or 8000 series to catchup with 683. Also when you increase the volume please decrease the bass as well.
You need 8ohm 55w to 90w or 4ohm 80w to 110w speakers.
Jul 20, 2014 | Marantz PM6004 Integrated Amplifier
Red flash light blinking.
That's a short circuit indicator. If you have some electronic skills u can repair it, else send it to a repair shop.
Apr 20, 2014 | Marantz PM6004 Integrated Amplifier
Find toshiba A1265n tranzistor
Are you looking for a 2SA1265, try MCM Electronics, or Mouser Electronics. Both in USA. If it's no longer available, you should be able to get a sub, however you will have to get a complement for the new subbed transistor.
Jan 31, 2014 | Marantz PM6004 Integrated Amplifier
I have a Mitsubishi WD-62525 TV the lamp red light started to to flash red so i replaced the lamp did not fix the problem so i replaced the lamp ballast light is still flashing red...can someone please...
please count the flashing led light on the front..
after you count click this link www.fixya.com/users/bugoy31
then choose any of my services to help you fix it..
Feb 03, 2012 | Mitsubishi Televison & Video
Jumbo remote can you please send me the codes for the jumbo remote sn (807245000020) for the rca tv thanks for your help if you can
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 24, 2008 | Computers & Internet
Need codes
Magnavox codes: 0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171.
Cheers!
IrishDruid
May 17, 2008 | Universal Remote Control DIRECTV Universal...
Please help
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Cheers!
IrishDruid
Feb 16, 2008 | Universal Remote Control Hampton Bay...
Marantz PM6004 Integrated Amplifier Logo
44 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
