Question about Conair GS23 Jet Liner steam hand-held garment steamer
Steam won't come out
It is clogged and won't allow steam
My euro pro ironing solution model 1000 does not heat up or allow steam to be released. It does make steam. What could be wrong?
The steam passages may be clogged, especially if ordinary water containing minerals was used to fill it. The instructions for your Euro-Pro iron probably specify use of distilled water.
Aug 24, 2016 | Irons
It's clogged up and want steam.
I don't have that particular model but my Rowenta as a self cleaning setting.
However, I am going to assume yours does not have that feature. In a jar or pitcher, mix 1 cup of vinegar and 1 cup of tap water. Pour that into the reservoir and allow it to sit an hour, then turn on your Rowenta and with lucky you should see some steam. If so allow it to steam ... checking it often to make sure nothing is being damaged by pressure or over heating. If you run out of solution before the iron is steaming correctly... repeat. It may take a few tries at this before you get some serious steam.
Feb 26, 2013 | Irons
Issues with Rowenta Steam Iron DG 05030 steam hose
Does your iron have a self cleaning feature? It sounds to me like you have calcium build up and when you squeeze the hose it displaces the "clog" just enough to allow steam through.
Nov 12, 2012 | Rowenta Steam Generator DG050 Iron
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
My argos steam generator iron is leaking and now does not produce steam, whats the problem and how can i resolve this problem?
tank or ports clogged: Disassembly and inspect , replace tank and seal if badly clogged or leaking. Emptying iron after each use allow heat to evaporate emaining water and help preventing clooging. Inspect valve and linkage: clean and replace as necessary.
God bless you
Jul 22, 2012 | Irons
The iron has plenty of water in the reseviour but will not steam. I have press the steam button and steam comes out but it will not steam otherwise
Your iron may be due for a cleaning. After awhile the ports inside the iron become clogged with mineral deposits.
Try using a mix of 1/2 white vinegar and 1/2 water. place the mix in the reservoir and allow the iron to heat up for steam until the reservoir is empty. Then do a second round with plain distilled water. Clean the the iron plate of residue after it cools.
If the vinegar mix does not work (and you can do the mix a few times) try using a product such as "Lime Away" or "CLR" to dissolve the deposits. Hope this helps.
Jul 12, 2009 | Irons
Burst of Steam
if no steam at all, there is most likely a small port where some particles have clogged...fill it with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 23, 2007 | Conair DPP4000 Iron
Water and iron heats up but no steam comes out.
there is most likely a small port where some particles have clogged...fill reservoir with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 18, 2007 | Euro-Pro Steam Generator EP8001 Iron
Conair GS23 Jet Liner steam hand-held garment steamer Logo
85 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Conair Iron Expert? Answer questions, earn points and help others
