Question about Fostex Mr16hd 16 Track Digital Recorder
Won't record and can't get effects to work
I can't get the effects to work and i can't get the machine to record on any of the tracks i can get vocals on the microphone through the headphones but it won't record
How do i get reverb to vocals? phonic powerpod 1860 delux
Use use an echo or reverb chamber for live recording through a desk.
A recorded vocal can be processed using a digital recording program like Audacity which is free. In it you will find a re-verb plug in which will allow you to add this effect.
Audacity Free Audio Editor and Recorder
Apr 17, 2015 | Music
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
When u export the track down too a wav.form and i convert it too mp3. if i listen too it in headphones i can only hear the vocals in the right earbud.
Well, did you run the vocals through a mixer and send to BOTH channels of the Lexicon Alpha? If you connect the mic to only one channel you will only get one channel UNLESS you process the .wav file and PAN the vocal channel into both channels when outputing to your MP3.
Jan 06, 2011 | Lexicon Alpha Personal Recording Studio
Question- Can I record songs or musics multi-times? I mean, record acoustic Guitar first, and then record Drums,other instruments Vocal like this. Not at a same ...
Here are some good links for you:http://audacity.sourceforge.net/ ( Audacity is a free recording program ) also:http://www.reaper.fm/ ( Reaper is the software I use and is full featured and worth the licence fee and free to try) also:http://www.recordingreview.com/ ( excellent site to answer all your recording questions. Note the free download.)
Aug 28, 2010 | Tascam Music
I want to buy a Tescam 2488neo. But i got a question before I buy it. Question- Can I record songs or musics multi-times? I mean, record acoustic Guitar first, and then record ...
Here is a link for you to look at:http://www.tascam.com/products/2488mkii.html Look under resources to download the manual or a Beginners Guide to Recording.
Aug 28, 2010 | Tascam 2488mkii 24 Track Recording...
I want to record vocal voice trhought mic on psr 9000
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
Jul 29, 2010 | Yamaha Music
Fostex MR 8 HD\CD adding treble and bass?
It APPEARS that the MR8 does NOT include the ability to EQ. They have delay effects and the like built in, but no EQ.
To answer your question then, you would need to have an EXTERNAL EQ unit and loop the vocal through that unit to do EQ to do it right.
When mastering, the "powerful/natural/and bright would be filters that will emphasize the bass (powerful) or the treble (bright) but these are really not EQ's and you can ONLY choose one at a time.
Jan 13, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
I was just wondering if its best to record seperate tracks at different times of if its ok to mic my guitar and mic the vocals using two inputs but recording at the same time?
Whichever works best for you is best. You can always lay down a scratch track for each like this and then lay down another track to replace whatever you didn't like using the scratch track as a guide. Erase the scratch tracks that you don't need before you mix down. I hope this helps.
Nov 26, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
Oct 18, 2008 | Boss Micro BR Digital Recorder
Boss BR900CD External MIDI
I'm not totally familiar with that Boss Digital Audio Workstation but it sounds like what you want to do is record both the music and vocal track at the same time. If that's the case I believe you can push both "Line" and "Mic" input buttons (perhaps not exactly named as such) at the same time to record both simultaneously. Otherwise I would suggest copying the music to it's own stereo track (or two individual tracks, each panned opposite from one another to maintain stereo) and then record your vocal track separately. That way you can record several takes and edit down the best parts to one final track.
I hope that helps.
Dec 02, 2017 | Boss Micro BR Digital Recorder
Fostex Mr16hd 16 Track Digital Recorder Logo
19 people viewed this question
Top Fostex Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Fostex Music Expert? Answer questions, earn points and help others
