Question about Conair HC100RCS Hair Trimmer
Changing blades Can't put it together
I think that I over tightened the lock nut on one side (not using a tort wrench) after changing the mowing blades. I don't think it is cutting now. When I take the blades off from cutting, one blade...
there is a star shaped, or other, pattern on the bottom of the mandrel which fixes it into the blade. this has stripped so the blade is freewheeling on the mandrel. if you cannot remove the blade bolt, I think you are going to have to remove the deck and take it to a fabrication or machine shop to have them remove the blade from the mandrel. then you buy a new mandrel and a new blade, at a small engine repair shop, put it back together. take a picture of the top of the deck before you remove the deck belt so you know how to put it back on after you have the new mandrel bolted in. if it is old you may just want to replace all the mandrels while you are at it. they are less than 50 bucks each.
Aug 24, 2011 | Toro Garden
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
The spring has fell out of the head when i was changing top i dont know how it goes back together
pull the black thing with the little blades until it detach, put the spring inside the hole, reassemble
May 09, 2010 | Braun Silk-epil 3370 Epilator
Took oster blades apart and now don't know how to put them togeth
First thing about Detachable clipper blade are Tension and straightness, You need a special tool to set the tension on your blade and the spec's on how much tension, plus you need to set the straightness of the tension spring. With out these tools your blade will not cut, even if some body sharpens the blade and do not set the tension correctly and straightness. You need to send it to a professional sharpening company, mannyssharpening.com has a mail order service he charges $8.00 to sharpen set to factory spec's and this price includes return shipping, they are fast in service.
Mar 26, 2010 | Oster 76076-010 Hair Trimmer
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Jan 25, 2009 | Ryobi 18V Hedge Trimmer
Changing a belt
Take off the bottom plate, look in the bottom to see if there are any screw, could be 2 of them, then from the bottom there is a slot on each side of the top cover, using a flat screwdriver, insert blade into the slot and pry up to release the locking tabs. Belt # is 38528040. Put the bell over the brush roll, put belt thru opening and put atound the motor shaft, put back together.
Jan 22, 2008 | Vacuums
Put it back together
Purchase the DVD on "How to adjust your trimmers and clipper blades" at www.alexccampbell.com
Jan 15, 2008 | Andis Outliner II Hair Trimmer
Conair HC100RCS Hair Trimmer Logo
35 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
