Question about PowerDrive 300 DC to AC Power Inverter with USB Port
Fan broken does not run
No suction
I presume the motor is running, take the front brush roller off and check the fan is still intact. Possibly broken fan.
Mar 30, 2014 | Kirby Ultimate G Bagged Upright Vacuum
Thermostat won't keep furnace fan running
You probably have a loose or broken wire to the fan relay. Check the wires on the thermostat first. Pull up on the bottom of the thermostat to remove it from the wall plate. You should see several screw terminals and the conductor wires that should be connected to them when you look at the wall plate. Check if any of the wires are disconnected or broken. If a wire is broken, strip a portion of the unbroken section of the wire and secure it to the appropriate screw. (The fan relay terminal is G for most setups.) If none of the wires are loose or broken, then you have to check for damage to the wires between your heating system and the thermostat or at the heating system. It could be a bad wire going to the jumper on control board or damage to the board itself.
I hope this helps. If the problem is not at the thermostat, you may need to have a professional diagnose and fix the problem. However, if you post additional comments about your heating system, Fixya experts may be able to help you diagnose the problem.
(we had the broken wires at the thermostat keeping the fan from working in the past. It's an easy fix if you are willing to handle small wires carefully.)
Jul 05, 2013 | Honeywell TH1100D1001 PRO 1000...
95 lexus es300 over heats when ac is turn on
Is your radiator cooling fan operating when the A/C is turned on? The cooling fan should be running at all times with the A/C on. If it does not, then your problem is being caused by a bad cooling fan motor, a bad cooling fan relay, a broken fan motor circuit, or broken fan control circuit.
Aug 27, 2011 | Lexus ES 300 Cars & Trucks
Thermo fan will not work on 1996 klx 650, when engine is running or hot, there is a wire to the sensor and another which is broken, beside it. Should the broken wire be connected to something? If so, what?...
Hello;
Let's figure this out. Broken or otherwise disconnected wires usually cause an open circuit preventing adequate current to a componant. Two wire switches act as light switches do. they either close or open a circuit.In this case, the warning lamp or fan relay is ativated when the temp rises. Cold, the circuit is open/ broken preventing any controlled componant from activating.
First check for any power/voltageat the disconnected wire and the connected wire. Which ever wire that is powered is the supply wire. The one without is your controlled componant wire. Touch the two wires together, bypassing the switch. The fan should come on and turn off when disconnected again. Ignition switch needs to be on.Because of the load the fan pulls, a relay is between the fan and switch.
The switch closes powering the relay, then relay close contacts closing a secondary circuit which in turn permits power to the fan. The fan circuit is powered by the battery and controlled only by the relay.
Yuup, two circuits. Switching and fan drive circuits. Yes, Hook the wire back onto the switch after testing as outlined here. Good Luck and remember to always verify power (fusec ondition). _Ned_
Apr 03, 2011 | kawasaki KLX 650 R Motorcycles
Cooling fan for my lumina will not kick on, causing my car to over heat.
CHECK COOLANT FAN FUSE AND RELAY.IF ALL IS GOOD YOUR COOLANT TEMPERATURE SENSOR FAULTY. AT CERTAIN TEMPERATURE LIKE 190 TO 200 DEGRESS COOLANT FAN WILL TURN ON.BUT FIRST CHECK COOLANT FAN.HOT WIRE IT.IF FAN DONT RUN REPLACE COOLING FAN. IF FAN DOES RUN YOU HAVE BROKEN OR DAMAGE WIRE IN ELECTRICAL CONNECTOR.FAULTY PCM.
Feb 25, 2011 | Chevrolet Lumina Cars & Trucks
Car is running hot, fan not working,how can i fix the fan?
This can either be..
1. A broken fan (the electric motor is damaged and wont turn)
Test it with a vault meter, find the coupling where it plugs into the relay, and see if there is a vlotage going to the fan
2. The relay is broken
If you follow the fan wiring back to the engine, usually around the radiator it attaches to a relay, this senses temperature and send power to the fan. These can fail. Breakers yard for pennies for this, a few more pennies for a fan.
Dec 19, 2010 | 1994 Toyota Camry
Fan runs in reverse but not in forward. Motor
There is a capacitor connected on the fan motor it must be broken. The explanation is a bit technical but since your description match on my previous experience, I would conclude that it is really the cause of your problem.
Oct 06, 2009 | Dryers
Broken fan on compaq
don't keep running it until you replace the fan. Look for one on ebay or around the web. It is shutting down because of heat. A $20 fan could cost you your whole laptop if you keep running it.
Jun 03, 2009 | HP Compaq Presario CQ50-110US Laptop
Fan won,t run on 2000 Ford Contour
fan motor may be bad. also could be a sensor. you can jump the fan motor off of the battery to see if it works.
Jan 06, 2009 | 2000 Ford Contour
Changing fan
My solution is one that only works if the vacuum is a spare... To get mad at it and throw it in the garbage...
My thought though on what the problem actually was... Seeing as where the vacuum came from and what the problem was, that it was run with the fan broken causing more damage to the motor and therefore making it impossible to fix with just a fan. I would suggest that if your vacuum sounds different than it has before, stop running it and see if there's something you can do to fix it and if not then don't keep running it. Coins are the main problem with a broken fan and are not made to be sucked up by a vacuum cleaner.
Jul 16, 2008 | Eureka 1934 Bagged Upright Vacuum
PowerDrive 300 DC to AC Power Inverter with USB Port Logo
26 people viewed this question
Top PowerDrive Electronics - Others Experts
Are you a PowerDrive Electronics - Other Expert? Answer questions, earn points and help others
