Lights flash when switched on - Washing Machines
On my 97 honda accord when the car is on and the lights are off everything flashes. The dash lights, the four ways, and every light in the car. When the lights are on tho it's ok, until you go to use the...
Your multi-function switch is likely toast and shorting internally. Removing the column shroud and inspecting the wiring will tell you if it's wiring. Given the fact the headlamps work but everything else doesn't suggests multi-function switch.
May 10, 2014 | Cars & Trucks
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
Should my hazard light switch flash when my hazard light are on my crv is 2004
If it does, then yes, it's supposed to. If it doesn't, as long as the hazard lights flash like they're supposed to, then all is good. Most hazard light switches don't flash. Some do. The likelihood of just that little bulb in the switch not working is almost zero.
Aug 14, 2013 | Honda CRV Cars & Trucks
Have a 3 switch to heater light and fan. when i turn on heater with light on dim, flash/spark behind heater switch. is this normal
You have a triple switch that controls bathroom heat, fan, light combo.
When lights are off inside room, and you flip the heater switch, you see a flash of light inside the switch.
The switch is mounted in electrical box. If flash is inside the box where electric wires are, then that is NOT normal and should be looked after by checking connections and securing wire nuts.
http://waterheatertimer.org/How-to-twist-electric-wire.html
If the flash is inside the switch, then that can be normal. But it also might be time to replace switch if switch is old.
What happens inside a switch is that 2 brass connectors come together.
The amp draw from heater is large, so a lot of electricity suddenly passes across the brass connections and produces a flash of light.
If flash is accompanied by a sound, for example crackling or fizzing, and/or you smell electrical burning, then that indicates the switch needs to be replaced.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Broan-NuTone FAN CONTROL SWITCH
Installed the prestige remote start(aps687n) on my 95 jeep grand cherokee but when i try to remote start my parking lights just flash 7 times and nothing happens. Any ideas???
Yes, the seven flashes mean that the tachometer setting has not been programmed. If you hooked up a tach wire (green with orange stripe) to an uncommon coil or injector wire, then you have to program tach: turn ignition on, press and release programming switch three (3) times. The parking lights will flash once to confirm. Turn ignition off. Press and hold programming switch. While holding the programming switch, start the vehicle. The parking lights will flash to confirm that the remote starter is getting a tach signal from the vehicle. Continue to hold the switch for approximately 15 seconds.The parking lights will continue to flash while holding the switch. Release the programming switch. The parking lights will come on solid for one second, then go off. The tach is not programmed. Turn ignition off. Test system.
Sep 19, 2010 | Prestige Remote Start
Dash board of my 2000 crysler voyager keep flashing, and the out side lights do de same thing.
the hazard switch is the problem or it is cause by passive alarm, remove the hazard switch or hazard fuse and observe the function of the lights, if lights stop flashing, change the switch, if continous flashing check the keyless entry reciever or the body control module
Aug 06, 2010 | 2001 Chrysler Town & Country
My BX23 rear yellow lights flash all the time...even when tractor is turned off. I have disconnected the battery cable to stop the immediate problem but need to see the wiring diagram to figure out why...
The hazard lights are wired so they will flash when the hazard switch is on, regardless of whether the tractor is running. Assuming you have tried flicking the hazard light switch on and off, and the lights flash no matter what position it's in, then I think the hazard light switch is shorted. Pull one of the wires off the back of that switch to stop the flashing, then order a replacement switch - it's not an expensive part. Good luck!
Jul 07, 2010 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
When you switch on the set the light comes on flashes and goes of
Depending on what tv you actually have, it could definetively be a power supply problem if the light is flashing. I would suggest to get it professionally looked at, at a reputable repair center. Sorry, Good Luck!
Jun 11, 2009 | Samsung Televison & Video
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
