Question about Toshiba 26AV502U 26 in. LCD HDTV
NO PICTURE BUT HAVE AUDIO
WHITE SCREEN
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
Oct 01, 2015 | Samsung LNT3242H Television
Sony Bravio screen went white could still hear and see faint picture
please call an authorized sony service center near you... check for the number on the sony site for your country
Aug 28, 2014 | Sony BRAVIA Televison & Video
Can only get a partial screen with netflix. Audio fine
Change your resolution settings in System Preferences. Open System Preferences, and Open Displays. Then Click resolution size: Best for Display.
Jun 10, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Picture for Wii game is in black and white only.
What type of cables are you using? My presumption is that you're using Component Video Cables - Red, Green, Blue for video, Red & White for audio.
If one of the 3 video cables is mixed up or poorly connected, you could see a Black & White image on the screen. I suggest double checking your cables for tightness and correct color attachment. Also be sure the red video is not mixed with the red audio cable. The red audio cable is marginally thinner and probably physically attached to the white audio cable.
May 05, 2011 | Nintendo Wii Console
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
Green screen, white lines. Audio fine.
You most likely have a bad picture tube. Green gun is shorted. Usually a set this size is not economically feasible to put a new tube in. You may also have a green drive problem on the CRT board. Have a shop check it out for you before junking it. Thanks for using fixya.
Dec 05, 2009 | Philips Televison & Video
Black and white stripes, no picture
just clean your projector board that connected to the main board, just clean the port.
Oct 08, 2009 | InFocus Play Big IN1 DLP Projector
GPX PD808B dvd player has no picture. its all white.
portable DVD's encounter that problems more often.because of its folding action,the flat wire connecting the screen to the DVD board breaks and causes no picture.try to open it up and check it or bring to a tech.
May 28, 2009 | GPX PD808B Portable DVD Player with Screen
Toshiba 26AV502U 26 in. LCD HDTV Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
