Question about Dacor DMT2420 1200 Watts Microwave Oven
We have a de6840744a samsung microwave oven built into our rv and the buttons on the front panel just quit working, cant set clock, cook etc help.
  • 2 more comments
  • bkmr99 Jun 16, 2009
    i found the microwave code on the inside door jam, where else would it be???
    i will try the reset thing when i plug the trailer back in.
  • bkmr99 Jun 17, 2009
    found the number on the door panle and it said code not model number.
  • William Miller
    William Miller May 11, 2010
    Did that tag say "model number" next to that number?
    On an over the range model, the model number tag is usually inside the cooking cavity, on the front edge of the cooking cavity, on the left side of the control panel frame, or on the right edge of the door, and visible only when the door is open.
    On counter top models, it may be in any of those locations, or on the back of the microwave.
  • William Miller
    Is this the "model number" as shown on the tag / in the microwave?
    That doesn't look like a proper Samsung model number.
    Sounds like a keypad problem, but it may need a reset.
    Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work,
    leave it unplugged for about 5 minutes. Then let us know if the hard
    reset does not fix it.
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave oven push buttons
Can you post the model number?
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
We should be able to help you with this.
Posted on Nov 17, 2007
SOURCE: samsung microwave oven (touch panel problem)
you can use the express button in touch pad,
Posted on Jan 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave stops after about 2 seconds, also have to reset the clock each time
TO mdambros
You have a bad magnetron. We see this over and over.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You'll save a lot by taking it in yourself.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
TO guest (Panasonic oven)
The door switch you suspected is bad, and it must be replaced. They normally cannot be cleaned or burnished and be reliable.
See http://www.microwavedisplay.com/doorsw.txt
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jul 01, 2008
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
How do i fix my clock from military time to regular time
Hi Tinay
I found this on page 10 of the manual:
"MY SETTINGS
Your new microwave oven can be customized to suit your
personal preferences. Simply press the My Settings
button to configure the following options
No. 3 - Clock display control 1=12HR 2=24HR"
Link to manual page 10 --> Samsung SMH1713 User Manual Turning On The Power For The First
Trust this helps, regards Alan
Mar 04, 2015 | Samsung SMH1713B 1.7 cu. ft....
Magic chef mco160s microwave control panel not working
That would be a defective membrane keypad.
If it's still available, and you or someone you know might want to replace it, here's a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag in or on the microwave here.
Jan 08, 2013 | Microwave Ovens
Sharp R395 Microwave.. cant set clock.
Sounds likein the moving you loostened wires in the front panel or flexed the circuit board inside. You will need to open the control panel and inspect it. It could also be just some dirt or dust getting on the controls....blow it out with clean dry compressed air!
Dec 31, 2012 | Microwave Ovens
Worked perfectly today for lunch and now won't cook anything....all looks like it's working all controls work, clock etc but no cooking
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 21, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Stuck on demo and cild lock
My Samsung did this as well. Unplug for at least two minutes and plug back in. Press the clock button twice. Set the time and press clock button once more. Doesn't have to be correct time, any time will do as you can go back and set correct time later. After pressing clock it should be out of demo mode. Try 1 second on high cooking. This should take care of the problem.
Aug 23, 2010 | Samsung MW4699S Microwave Oven
Clock works panel lights up but it won't heat
All of a sudden last nigh it just started acting weird the panel works and the clock etc works as well as all the cooking setting. but it doesn't light up inside and when I close the door to my GE Profile Eterna Space maker it starts huiming like its cooking something
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
93 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
