Question about Cook's Essentials CooksEssentials 6.5 qt. Round Nonstick Stainless Steel Pressure Cooker - Copper -
Floating valve is missing
I need to replace the floating valve
Gas is runnung out the over flow tube and bike wont start
Either something is stuck in the float bowl valve or similar. You will need to shut off of the gas, drop the float bowl, check that the float move and closes the valve. If everything looks good and the valve actually closes, then there is a chance the float is fuel logged, or soaked with fuel. It won't float then. Replace the float, clean and/or replace the valve, clean the seat and check for scoring. New gasket on the float bowl, tighten it up, and you should be set.
Dec 14, 2012 | Motorcycles
Water is not filling up.
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
Water not entering the dishwasher
Hi
Daniel
Jul 21, 2011 | Siemens Dishwashers
Dishwasher will not fill have changed the inlet valve but still not filling.
Hi
Daniel
Jul 20, 2011 | Bosch Dishwashers
Dishwasher wont let water come in
Hi
Daniel
Jun 19, 2011 | Dishwashers
Fuel comes out of overflow while idling. We have overhauled the carburator and check the float level several times and still have same problem. We replaced the vapor valve in the vent line from the tank...
Replace the needle in the float bowl.
You say you set the float level several times. I assume you know the float level sets with the carb on angle of 15 to 20°. One thing you try is setting the float level so that it's about one millimeter lower. This will put just a bit more pressure on the needle when the bowl fills.
Good Luck
Steve
Dec 24, 2010 | 2003 Harley Davidson XLH Sportster 883...
How to troubleshoot toilet sump pump?
Unplug the sump pump. Bail out the sump pump to expose the pump's machinery.
Inspect the rod attached to the motor on the top of the sump pump. Move it up and down manually to see if it moves smoothly. Corrosion will keep the rod from moving smoothly. Clean the float road with steel wool.
Inspect the float ball. If it contains water, you need to replace it. Unscrew the float ball from the end of the float rod and screw on a replacement float ball.
Inspect your sump pump's check valve. It has an arrow on it. The arrow should be pointing away from the pump. If it's pointing towards the pump, remove and reinstall the check valve.
Locate the small weep hole between the check valve and the pump. Clean it out with a pipe cleaner.
Inspect the impeller, which is the fan-like piece that sits near the bottom of the pump's tank. If it is clogged by debris, then it will not turn properly. Unbolt the impeller and clean away any debris you find. Reinstall the impeller with new gaskets and sealant. Locate and replace the mesh filter in the sump pump, since only a damaged or missing filter would allow debris to get near the impeller.
Below is troubleshooting work, web link, through to assist you in that.
http://www.plumber-washingtondc.com/articles/sump-pump-troubleshooting
Jun 25, 2010 | Plumbing
NEED TO KNOW FLOAT LEVEL HIGHT. REPLACED FLOAT AND NEEDS LEVEL ADJUSTED. FUEL OVER FLOWING WHEN BIKE RUNNING.
the common rule is to have it adjusted within 2mm of where the gasket meets the carb and bowl. get a clear hose about 6 in long and connect to where the fuel is flowing out of while bike is off. bend it to where the side of the hose runs up and down next to your carb. it will show where your level is. then keep adjusting till its around the gasket. also check to make sure the rubber valve isn't missing or damaged in your float.
Apr 03, 2010 | 2003 Suzuki RM 250
Gas is leaking where the air filter is
your carburetor's overflowing. This is caused by the needle valve in the carburetor not sealing, or the float's faulty. You'll need to clean out the carburetor and investigate whether the needle valve is stuck, corroded, or missing the o-ring, or the float has a leak, is crushed from getting frozen with water in the fuel, or similer.
Mar 20, 2010 | Garden
How many pieces are inside the bowl in the carburater
float and needle valve small clip to hold needle valve check float adjustment and that float not porous or sticking open
Oct 05, 2009 | Coleman Powermate Premium Plus 6250W...
Cook's Essentials CooksEssentials 6.5 qt. Round Nonstick Stainless Steel Pressure Cooker - Copper - Logo
Top Cook's Essentials Home Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Ellen Tumey
Ellen Tumey
Are you a Cook's Essentials Home Expert? Answer questions, earn points and help others
