Question about Eliminator Hudson Sprayer - 1 Gallon, Model# 30161
Broken "O" ring . It does not seal
The blue O ring does not seal so there is no pressure for spraying.
I replaced water seals and now i have an oil leak. however i have good pressure
I don,t nothing by the brand of this pressure washe but i think there is also a large round oil seal is maybe broken or is not good or ring is not in his seat. but a cuff-kit has most times has not the 3 oil seals on the pump cover under the brass pumphouse this are the first rings simmer rings but before you have no problems with oil leak , are they not forget ? look carefully on the image of the cuff-kit or on the site of the brands models spares . if the brass pumphouse was released then you have replace the 3 simmer rings oil seals yet.
Oct 03, 2015 | Annovi Reverberi AR SJV2.5G27D-F7 Pressure...
2003. Why does it move forward but not in reverse?
There are several thing's that can cause a no reverse !
No Reverse, Slips in Reverse
Checks
Causes
Reverse Clutch
No apply or slipping
Piston and Seal Assembly (457)
Binding, cracked, or leaking
Inner Seal (456)
Plugged orifice
Clutch Plates (460-463)
Worn friction or broken splines
Snap Ring (459, 464)
Out of position
Housing (454)
Cracked, plugged feed holes, or broken tangs
Housing Retainer and Ball Assembly
Missing or out of position
Springs (458)
Binding
Reverse Clutch Fluid Routing
Fluid leak or restriction
Driven Sprocket Support (95)
Leaking seal rings
Porosity, damage, misalignment
Channel Plate and Gasket, and Valve Body, Gaskets, and Channel Plate
Porosity, fluid leak across the channels, misalignment, damage, or fluid restriction
Low and Reverse Band and Servo
Servo Piston (69)
Broken or binding
Servo Piston Seals (71, 72)
Leaking
Servo Pin (67) and Springs (66, 68)
Binding
Servo Cover (73)
Broken, loose, or leaking
Low and Reverse Band (111)
Broken, worn, or out of position
Anchor Pin (64)
Broken
Fluid Feed Tubes (83)
Broken, bent, or plugged
Missing or leaking seal rings
Transmission Case (1)
Porosity, fluid leak, or restriction
Shift Linkage
Disconnected or misaligned
Manual Valve (800) and Link (802)
#1 Checkball
Missing, no low band fluid
Fluid Level
Low
Fluid Pressure
Low
Refer to High or Low Line Pressure .
Most likely your trans needs to be rebuilt !
to
Jul 26, 2015 | Pontiac Grand Am Cars & Trucks
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
Can NOT release the attachment
Had the same problem.
Spray Wd-40 or similar in there. Makes the O-rings work better. Soap and Sun and water makes the seals thirsty.
May 26, 2015 | AR Blue Clean AR383 - Pressure Washer
KARCHER PRESSURE WASHER
It is a "O" ring and this is a common problem for that make of washer
New rings are available but I used a larger diameter material "O" ring from a seal shop as the thickness of the oem ring doesn't apply enough pressure to the plate to seal off
I also used locktite blue on the ring and that fixed the problem
take the ring along and get one about 1/2 mm thicker
Apr 08, 2015 | Cars & Trucks
Spark plug has oil inside of it y would this happen
SOUNDS TO ME YOU M AY HAVE INTERNAL ENGINE DAMAGE IE BROKEN RING
Nov 01, 2014 | 2002 Nissan Maxima Spark Plug
What does blue smoke mean
Burning oil. Could be a couple of things. Possible your valve guide seals are warn out. If its blue smoke mostly when you first start the car, its likely valve guide seals. If its continuously smoking blue, its more than likely a broken or warn out piston ring. If its just every so slightly blue in tent, it might be worth a try to replace your PCV valve first. When the PCV valve gets completely gummed up, the pressure inside your valve covers has no way to vent other than forcing its way through the valves into the cylinders often times taking oil with it. Since PCV's usually only run out about $10 its worth a shot. Other wise, you've got a decent overhaul ahead of you for either piston rings or valve seals...on a 12 year old car most folks would either choose to scrap it, or live with the blue smoke while monitoring oil levels and watching for fouled plugs. Hope that helps and good luck!!
Jun 17, 2014 | 2002 Nissan Altima
When starting toyota fortuner 3.0 liter blowing blue smoke what is causing this
It is oil smoke. The most common causes are worn valve guide seals, a faulty PCV valve, or, worn or broken oil control rings on the pistons. Only 1 or 2 cylinders need be at fault.
Check the PCV valve for fouling. Have a compression test done. If readings are low or irregular, pour a few ccs of engine oil into the suspect cylinders thru the plug holes. If compression readings then improve, it is probably the rings at fault.
Less common causes are worn big end bearings spraying excessive oil up the cylinder walls, or a leak from the head gasket, oil to cylinder.
Apr 30, 2014 | 2004 Toyota Camry
Low compression on cyclinder three
Low pressure on a cylinder indicates a valve seating problem --- piston problem.- broken ring RE do the test but this time squirt about 6 pumps from an oil can in the plug hole first and see it there is a marked increase in pressure.( seals the rings) If nothing it is most likely a burnt valve head.An engine knock would indicate a broken ring
Mar 13, 2013 | Cars & Trucks
Eliminator Hudson  Sprayer - 1 Gallon, Model# 30161 Logo
75 people viewed this question
Top Eliminator Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Eliminator Garden Expert? Answer questions, earn points and help others
