Question about Kenwood KT-57 Stereo Synthesizer AM/FM Tuner
120v? type ofspeaker hookups?
Is it 120v & what kind of speakers go with this?
It says frequency response as 40 Hz to 170 Hz (Subwoofer) and 200 Hz to 20 KHz (Satellite speaker). How it will manage frequency from 170 Hz to 200 Hz. Will this be affected
The sub-woofer will handle a frequency of 40Hz to 170Hz of the sound spectrum, and the satellite will handle 200Hz to 20KHz. There is frequency hollow that is, 170Hz to 200Hz; and it is not quite audible and noticeable to human ear. Gopakumar Gopalan Google
Apr 22, 2014 | Audio Players & Recorders
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
Hookup Blu ray player to Onkyo pre-amp for speakers
If you have audio out jacks from your tv, you would be better served hooking that up to the preamp. If you hook up the blu-ray player separately to both the tv and amp, the audio probably will not sync with the video correctly. The tv takes longer to decode the hdmi input and the audio will be ahead.
Jan 22, 2013 | Onkyo Audio Players & Recorders
Klh model 20 no volume
what kind of speakers do you have hooked up? make sure your cables from the speakers are good. you should have an RCA type hookup on your record player, make sure they are in there good too
Jan 07, 2013 | KLH Vintage Model 20 Turntable & Receiver
What type of speakers can i add direct to tv without using a amp/receiver?
Unless it has a hookup for external speakers do not do it---speakers must match inpedance of original speakers, wrong speakers can result in damage to audio circuit of set, cause reduced sound levels etc.
A inexpensive surround sound system might be a option......
Oct 23, 2012 | Pioneer PDP-4270HD 42 in. Plasma...
How to fix sound on my lg 42
Some simple things you may already have tried but I will list:
Unplug set for a while and then plug back and see if sound--when unplugged the set may reset.
In main menu make sure speakers are not switched off.
I doubt it is mute but if also using some type of box check that its volume is not all the way down.
If internal speakers put your ear right to them---hear low sound or a buzz or hum?
If using external speakers of any kind look at the hookup and switch to make sure internal/external is correctly selected
If NONE of these help you have an audio problem and should first contact LG (yes it takes time on the phone) to inquire if some common issue or a possible software upgrade is available for this.
Last: Some failure has occurred either in the audio circuit or something that feeds it.
Mar 22, 2012 | LG Televison & Video
No sound 72 inch samsung
If NONE of these help you have an audio problem and should first contact Samsung (yes it takes time on the phone) to inquire if some common issue or a possible software upgrade is available for this.
Mar 21, 2012 | Samsung Televison & Video
The screen on my ps3 kind of rolls and bounces...what is causing this and how can i fix it?
what kind of hookup are you using for the ps3 to the tv? it may be a loose hookup or you need new hookup wires.
Jan 10, 2011 | Video Game Consoles & Games
How to hook up speakders?
The monitor does not have output sound since it is only an input device. You will have to hookup the speakers to your device (laptop, computer, gaming console) that you are connecting to the monitor. The speakers in the monitor are ready to receive a signal so that it can amplify it and let you hear it. If you hookup your speakers to the monitor it is the same as if you were trying to hookup two sets of speakers to each other.
Nov 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
Kenwood KT-57 Stereo Synthesizer AM/FM Tuner Logo
16 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
