Question about Frigidaire FMCB115GC Microwave Oven
Fmcb115gc turntable motor
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
Opened door ,oven light blew out,turntable motor stopped also noticed power button next to timer button shows nothin when you try it. but you can put in cup of coffee it will heet up.
This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Apr 02, 2013 | Microwave Ovens
Cplmv169dc
see this steps and fix it. God bless you
First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Magnetron what is problem?
However see the table for test it.
Oct 04, 2012 | Electrolux Microwave Ovens
TURN TABLE NOT ROTATING
see the nex step and proceed with common sense and logically: God bless you
Microwave Runs, Heats, but turntable does not move This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
Jul 26, 2012 | GE Microwave Ovens
Phillips whirlpool microwave turntable not turning
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
Frigidaire FMCB115GC Microwave Oven wont stop
The only parts that are available for this unit by model number are the tray inside and the feet on the outside.
If you were adventurous and found a way to take it apart and remove the door switches you might be able to match them up at an appliance parts dealer but short of that it sounds like a lost cause.
I know that is not what you want to hear, and I as well do not like being the bearer of bad news.....
May 12, 2010 | Frigidaire FMCB115GC Microwave Oven
My microwave is still working but not rotating, what is wroong with it
There's a turntable motor in the bottom of the oven that drives a turntable support directly in some models, and a plastic coupling that rotates the turntable in others. Turntable motor failure is common, or there could be connections in the power to the motor that have gone bad. Sometimes the plastic of the turntable coupling cracks, and the motor shaft turns but the turntable doesn't.
You can check a turntable motor with an ohmmeter. A good motor will show fairly low resistance (a few hundred ohms or less) between its terminals, while a very high or infinite reading means it's bad. In most models of oven you get at the motor through and access panel on the bottom. Replacement motors for many brands are available, although they're not always easy to find.
It may be more economical to replace the oven if it's a basic counter top model. They are under $50 these days, and a replacement motor might cost $20 or more. Of course, you can continue to use the oven even if the turntable doesn't, you'll just need to turn the food yourself occasionally during cooking.
Hope this helps. Thanks for using Fixya!
Mar 08, 2010 | Microwave Ovens
Frigidare FMCB115Gc Has power won't start up
Could be a blown fuse in the HV transformer primary circuit,bad connections to the magnetron filament,open thermal protector or thermal fuse,
Sep 03, 2009 | Frigidaire Mid-Size Microwave
Turntable not rotating
HI, the turntable motor is weak and failing at this point, simply replace this damaged motor. this will eliminate this distraction.
Jul 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire FMCB115GC Microwave Oven Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
