Question about Jenn-Air JEC9530 Electric Cooktop
I took out an old cooktop which only has the black, white and ground wires. The jennair cooktop with 5 electric elements has black, red, white and ground. how do i connect these together.
  • 867 Answers
Sounds like the old one is 110 volts , and the new one is 220 volts. incompatable, as the 220 ones would work, but at half power if you didnt use the red wire. might work fine. omit the red wire and wee what happens
Posted on Jun 15, 2009
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
How to wire a jennair cooktop. I have 3 black wires all hot. The cooktop has 4 wires black, red, white, and green(ground)
The wire coming in should have the same colors, just match up the wire colors and wire nut them together with large wire nuts ad them tape them. ground the green wire to the ground screw.
That's all there is to it!
heatman101
Jan 26, 2010 | Jenn-Air JED8230 Electric Cooktop
Jenn Air cooktop has 4 wires Black, white, red, and green and my house supplies power with 3 leads white, black , & green. How are the wires hooked up to power the unit?
Old plug: green is ground, white and blace are both hot power. New cooktop: green is ground, WHITE is COMMON, black and RED are hot power. You are going to need an electrician to run a new circuit and plug for your new cooktop.
Aug 31, 2009 | Jenn-Air JED8230 Electric Cooktop
I need a wiring diagram hook up for a Jenn air 201595D Range top & also for a GE Double oven JKP36G0D1B0
Cook top manuals and installation.
http://www.jennair.com/catalog/product.jsp?parentCat=2&cat=12&prod=1457&tabOption=specs#info
Could not find installation manual on oven but did find manual. If you are just trying to wire to the house wiring you need to conect this way. Yo uwill have 3- 4 wires from the house. 1 white, 2 black or 1 black and 1 red. From range hook white to white Black to black or red they both are the hot line. and the other black or red to black or red from the house. If you have bare wires that is the ground There is 2 ways to do the hook up on the ground. 1st way is if you have ground in box from house wire them together. 2nd way is if there is no groung just wire it up with the white wire that is the netural line. It will be fine that way. If you can see in you main braker box the netural and the ground go to the same bus bar.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Good Luck and If you have any more ? fill free to ask befor you rate.
Jan 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Electrical hookup
no its 220 red to one 110 line blk to the other 110 line white to neutral should be a solid metel wire to take that to ground
Jan 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JEC9530 Electric Cooktop Logo
140 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
