Question about Samsung G3 Station 1.5TB USB 2.0 External HX-DU015EC Hard Drive
What does it mean when the power light flashes on my iomega hdd1h4-2 drive
Power light flashes
The device does not boot, flashing white light.
It's likely you have a failed drive. You might ask for help at http://www.iomega.com/support
Or if you need remote data recovery http://FreeDataRecovery.us
Aug 09, 2012 | Iomega Home Media Net HD Cloud 2TB (34766
Iomega Ultramax red light turns on at start.
It's probably the power supply. Iomega has been having lots of power cord failures. I had same problems and thought it was the drives until I did a internet search and saw lots of people having the same trouble. I called Iomega and they sent me a new cord. Problem fixed. It's the little black box that dies...
Apr 04, 2012 | Iomega ULTRAMAX 1TB TRIPLE INTERFACE...
My iomega hard drive Model No GDHDU has just stopped working the power light isnt on but the power lead is fine I CAN`T ACCESS ANYTHING PLEASE HELP
Your hard drive is not getting the power from the port u r connecting to. So please check it with other port . If the same behaviour then it is physically damaged and u have to take it to the service centre
Feb 01, 2011 | Iomega (33150) Hard Drive
Bought a new network hard drive 1tb iomega. Operating system requirements is XP. Saleman said it would update on line & work with windows 7. doesnot happen for me . Is it compatible or not? CD will not...
The drive will not update itself automatically. You will have to download the firmware update and update it yourself. You may also want to get the latest Manager software that is Windows 7 compatible.
Firmware Version 2.064: https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21149
Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
The blue indicator light is the Drive Capacity LED - Displays drive capacity information without logging into the administration tool.
a) Off: Drive is below 70% full. b) Flashing blue: Device busy. Drive Starting up or shutting down. c) Solid blue: Warning! Drive is over 70% full. d) Solid orange: Caution! Drive is over 85% full. e) Flashing orange: Critical! Drive is over 95% full. f) Alternating Blue/yellow: DHCP Server Unavailable. Your Home Media Network Hard Drive was not able to get an IP address. Check the network connections and router settings.
The white indicator light is the Status/Activity LED - Indicates the Home Media Drive's power and drive activity status.
a) Solid white: Drive powered up and ready. b) Flashing white: Drive in use, transferring data (reading / writing). c) Solid red: Drive not ready/Drive Failure. d) Alternating white/red: Boot device not found.
Dec 06, 2010 | Iomega 1TB Home Media Network Hard Drive...
I lost connection to my Iomega 500gb network hard drive. I tried to reboot it but the drive's blue light keeps flashing after power up.
In that case you have a bad connection caused by a hardware failure. Take out the hard disk from the case, put it in a desktop and try to access directly there. If you can then the electronics of the case have failed - you need a new case.
If you can't then you need a new hard disk.
Sep 18, 2010 | Iomega (33455) 500 GB Network Storage...
Is the cooler broken? Iomega Hard Drive do not start. The icon does not appear to the desktop and hard drive does not switch off the electricity, when push the power button. Only power and HDD1 lights are...
your hard drive failed and it cannot be read. What happened was the sliding arm on the hard drive got off its track or scratched across the entire platter. It happens if you drop it or hard drives die anyway after about 50,000 hours of use.
If there is important information on it you can have a expert remove the platters and recover your data as its still written on those platters but I believe it will be expensive too.
Apr 06, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Blue light flashing but imac not recognizing.
Iomega is not a recognized company with Apple and may not be compatible with Macintosh and may be a PC only product.
Jul 21, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Iomega zip port
First of all, make certain you are only using 100 MB disks in a 100 MB reader.
If the problem is more complex than that, I have several questions:
Can you read different disks?
what type of connection is the zip drive using with the computer? USB?
does the zip drive need an external power supply?
will the zip drive successfullly read disks when connected to a different computer?
does the zip drive appear under my computer at all? even as an empty drive?
what operating system are you using?
Mar 29, 2008 | Iomega Zip 100MB (31714) External ZIP...
No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Jun 21, 2007 | Iomega (33090) 250 GB Hard Drive
Samsung G3 Station 1.5TB USB 2.0 External HX-DU015EC Hard Drive Logo
54 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
