Question about LG LMV1650SW Microwave Oven
Lg microwave exploded hot water on my face
I had a measuring cup full of water in my LG microwave and after two minutes as i walked by it exploded and shot hot water all over my face
  • LG Master
  • 9,098 Answers
It's rare, but obviously can cause serious injury!
Your manual should address this, or for more on what causes this, read this article.
Posted on Jun 16, 2009
I want to know how many watts my 2002 jvm1430bd002 microwave has...I have googled this question and have answers ranging from 700 to 1200! what gives???
Conduct what the USDA Food Safety and Inspection Service calls a "Time-to-Boil" test, which will help you estimate your microwave's wattage. Add 1 cup of water to a microwave-safe 2-cup measure. Add ice cubes and stir until the water is icy cold. Pour out the excess water, leaving just 1 cup. Place the measuring cup inside the microwave. Set the oven for four minutes on high. Watch through the glass to see when the water boils. If it takes less than two minutes, the microwave is 1,000 watts or more; if it takes 2.5 minutes, the oven has a rating of 800 watts or more; if it boils in 3 minutes, the estimated wattage is 650 to 700.
How to Find Microwave Oven Wattage eHow
Jan 08, 2015 | Microwave Ovens
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Oct 11, 2013 | Panasonic 1974 Microwave Oven Cookbook &...
Oven is not making etables heat
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 07, 2012 | LG Microwave Ovens
We have a GE Spacemaker XL 1800 Microwave. There is dirt and moisture that has collected between the inside and outside glass. How can you clean this?
HELLO.
This is the solution to the cleaning issue.
1. Wipe the microwave inside and out with a soft cloth dampened with a warm, mild detergent solution. Rinse with a soft cloth dampened with plain water. Dry with a soft, dry cloth.
2. Put 2 cups of water into a 4-cup measuring cup. Place the measuring cup in the microwave, then heat on high for 5 minutes to loosen food particles that are stuck to the inside walls. Leave the measuring cup inside the microwave for 1 to 2 minutes, then remove and wipe the interior as in Step 2.
3. Remove the glass turntable and wash it in the sink with mild detergent or in the dishwasher. Handle carefully, as the turntable is breakable.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave does not heat as hot as it use to. What would cause that.
Here is a simple power test.
Place a measured cup of water into the microwave. Run the micro for 2 minutes. A 1000 watt micro will boil a cup of water in 2 min. Check the power output of your machine. It will be found on the model number tag. A 700 watt micro will take about 3 minutes. If this occurs, the machine is working properly.
Otherwise, check the outlet voltage, should be 110 or higher.
Outside of this, you could need a high voltage capacitor or magnetron.
Dec 30, 2010 | GE Microwave Ovens
What size fuse is a 250v 10a drawing fuse inside my microwave would a 6.3 32mm fuse be ok.its a lg ms-283 mc microwave
Chances are it is a standard 1/4" x 1-1/4" (6.3mm x 32mm) but I would suggest measuring it to be sure.
Here's an exploded view of that oven to help in disassembly.
May 28, 2010 | LG LMV1650SW Microwave Oven
I tried to reheat food and didn't get any results. Could I have ruined it by turning it on without food?
well if you keep on running your microwave without any thing in it then yes! it burns out the magnatron
(thats the bit the heat come from) and when there burned out its a dust bin jod as there very pricy to by and its not a smart thing to do trying to fit a new one by yourself,, you stand a very good chance of just killing yourself first,,to test your microwave opn the door put inside a cup of cold water and turn on the microwave for 3 mins on full power, the water should be boiling by then,,,dont put anything in the hot water like milk or it could explode in your face! just tip it away
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Get rid of the smell in my LG MC8087ARS microwave
I just read this in my microwave manual. It says to combine 1 cup water, grated peel and juice of one lemon and several whole cloves in a 2-cup glass measuring cup. Boil in microwave for several minutes using 100% power. Let sit in over until cool.
I imagine any type of citrus fruit would work just as well.
Apr 04, 2009 | Microwave Ovens
Plate getting too hot
I don;t think your plate is micorwave safe. Put the plate and a glass measuring cup with water in the microwave for 1 minute, if the plate is hot and the water is not the plate is not microwave safe. IF the water is hot and the plate is not. I don't know what the problem is
Sep 16, 2008 | Kenmore Microwave Ovens
LG LMV1650SW Microwave Oven Logo
79 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
