Question about Vidal Sassoon Sassoon Vidal 1875 Watt Hair Dryer
Vidal sassoon vs505 disassemble
How to disassemble hair dryer.
There is one Philips head screw near the top of the handle and there are four more behind the rubber on the handle grip. The rubber on the handle grip is attached to a curved plastic plate that has four clips that hold it to the handle, you have to pop the plate with the handgrip rubber off the handle to access the four screws.
Posted on Jul 05, 2015
How to disassemble Vidal Sassoon 1875 W (Blue) hair dryer?
hi
If the model is like this one you can use a paintbrush and with the hairdryer unplugged you can wipe the net full of dust. Then blow with air compressor if very dirty.
Plug it and enjoy
Feb 19, 2015 | Helen Of Troy VS783N3 - Vidal Sassoon...
Is it universal volt
It is not listed as such. You should not plug a 120VAC unit into 240VAC.
Nov 22, 2013 | Vidal Sassoon Sassoon Vidal 1875 Watt Hair...
How to dissassemble Vidal sassoon VSCL816. (e.g. scissors area). two phillips scresw unscrewed, but two shells of housing cannot be separated completely. Hint needed for taking away scissors. Scissors got...
I have a Vidal Sassoon Max hair clipper, and I suspect the construction of it is similar to yours. To take the two halves of the body shell apart you need to remove the blade assembly. Try this:
After removing the two visible screws, place your thumbs at each end of the cutting blades and push upwards.
The blade assembly should unclip, revealing two more screws underneath. Remove these, and the two halves of the body shell should come apart.
Graham
Apr 10, 2011 | Vidal Sassoon VSCL816 Beard Trimmer
Vidal sassoon model vs2085a streightners, red light wont stop flashing and they dont heat up ?
I have found that current devices that heat up (hair dryers, straighteners etc...) all are made so flimsy that at a certain heat point, the shut off.
I also have come to realize and expect that there IS A SHORT LIFE EXPECTANCY for any heating electrical product.
If your device is new, I would return it. If it's old, buy a new inexpensive one (on sale) .... MAKE SURE YOU BUY ONE THAT YOU KNOW IS GOING TO HAVE A RELATIVELY SHORT LIFESPAN. Silver color does not mean metal nor a longer lifespan. Buy cheap, use and replace as needed.
It's an eco-nightmare, but once a heating product goes out, it is too dangerous to even think you can fix it yourself without risk of potential major fire. It may look fixed and you then come home and it's burned to the ground.
Be careful and wise.
Jun 15, 2010 | Vidal Sassoon 21PC Hair Clipper Set Hair...
Replacement blade
GO ON LINE YOU SHOULD BE ABLE TO ORDER THEM FROM VIDAL SASSOON.
Mar 15, 2009 | Vidal Sassoon VSCL900T2 Hair Trimmer
Replacement Blades
I dont believe you can get replacement heads for non-professional clippers. If you are going to invest in a new pair you could go to Sally's Beauty Supply and purchase a pair that you could always get a replacement head for.
If you dont want to invest in a new pair you could bring that pair in there and see if any of the replacement heads they have may fit. There is usually eather 2 or 4 screws that will go in there. You could find one that looks the same and it may just work! Good Luck!
Mar 25, 2008 | Vidal Sassoon VSCL867 Hair Trimmer
Vidal Sassoon Sassoon Vidal 1875 Watt Hair Dryer Logo
188 people viewed this question
Top Vidal Sassoon Health & Beauty Experts
Anglia Clipper...
jasiel murphy
Jerry Greenberg
Jerry Greenberg
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
